Question about APC Smart-UPS UPS System
UPS issues with bad power
I have a ton of customers with dying machines from power glitches. What's the real issues, from your experience, with UPS vice power plus strips?
  • 21 Answers
A power strip with no surge protection is a waste of money unless allyou need are more outlets. Add surge protection and you have just that, surge protection. However a $15.00 surge protection power strip will give you just about your moneys worth of protection. the thing will trip if it senses a surge. A circuit breaker will do just about the same thing, and you still have to reset both.
UPS units inherently give surge protection, however, a UPS unit will kick in and take over powering the computer when it senses either high OR low voltage, therefore it gives you blackout and brownout protection. the new ones will then "properly" shut down the system if the abnormal condition persists for a set amount of time. In my opinion, that is cheap insurance for you system. A good UPS unit sells for under $100 these days and will almost totally protect a $1500 computer for however many years you use it. Hmmmmmmmmm Spend $100 now? or $1500 after the thunderstorm? Not much of a choice is it?
Posted on Feb 14, 2008
    Scholar:
  • 60 Answers
First, most of the UPS sensitivity can be adjusted. Setting a higher sensitivity will make the UPS compensable much faster if the current goes to high to too low thus always providing a good power quality to the equipments. For example, on a BackUPS RS the low level can be configured from 94V to 104V and the high level from 126V to 136V. An entry-level UPS such as the APC BackUPS ES will switch to battery mode as soon as the power goes out of the sensitivity range. On the other hand, a high-end UPS for workstation like the APC BackUPS RS has a feature called Automatic Voltage Regulation (AVR) that compensate at some extent without requiring the battery; this makes the battery last longer before needing to be replaced.
Second, most of the UPS have "Battery Protected" and "Surge only" outlets. Make sure that the computers are connected to the "Battery Protected". The "Surge only" outlets will only protect from parasites or surges like a thunder storm. They should be used for less important stuff like a desk lamp or devices with high demand peek such as a laser printer.
Third, the use of a power bar connected to the "Battery Protected" side should not have any impact as long as it is not overloading the UPS. Personnaly, I have a power bar connected to both my UPS.
Posted on Feb 07, 2008
Alarm 281
Seems to have had a power glitch, is the system back to normal?
Apr 11, 2014 | Eaton Powerware 9355 UPS System
I use a compaq ml350 server. When I switch on the power at the socket its blowing out the fuse. The problem started during electricity load shedding - i was switching between genset and electricity power....
the fuse blew for one reason, overload, and stops the fire from happening, that is its #1 job, the fire thing and smoke bad thing
and deathhh..
Never have PCs on or servers when doing power feed swaps.
of any kind unless you have the type that has expensive power frequency syncing,.. and full load dump protections. (ask)
let me guess you dont have this, nor a UPS on your server to save it.
what is this, it has a real name, this is generic, phrase.
embedded network.+
what ever this phrase means?, and what it is by name and model unstated, all I can say its not on a UPS, nor is its internal battery any good, or other power backup issues bad inside.
coin cell in side bad," or you load dump glitches its so badly, well, no need to say why, there its obvious.
even some homes the cable modem has battery now and more are bad. now. (huge problems with ignored batteries)
doing exactly that. as expected too.
Your server has RAID, like mine (DL380G7) has Cash ram
with battery on it , 1GB here, if bad battery on this, you will lose data on your HDD if you kill or bump power, AC, called load dumping, My RAID card allows power loss. and no data loss ever.
also load dumping blind invites, surges of overvoltage and blows to H3LL very expensive electronics. boom dead. $%$$$$
sounds like you need a real UPS there, between H3LL and $$$$ things.
This is how 911 service centers are built, done many.
ground up,. not just thrown together, not even close.
The run a HUGE UPS, $20,000 worth or more.
for you do use a UPS we need your load, actual (watts)
then 2x bigger UPS.
The gen set must be at correct voltage and freq, before the switch or even UPS can be damaged,
but some can run as low as 100v and 50hz.
so read the UPS spec first before buying one and to be sure the gen set cant damage it. (no gen set stated BTW)
In Hospital here we have a genset monitor that makes the genset delay the switch over until, all is perfect then switches. see?
or you will blow lots of things up. endlessly.
Nov 28, 2017 | HP Compaq 175-Watt Power Supply
98 chevy 1/2 ton. I was driving home and all of
vacuum booster went bad. the round canister behind the master cylinder. not a real tough job, but if you do not have much brake experience i would advise you to have it done
Jul 07, 2010 | 1998 Chevrolet C1500
Does not power on
Please check whether you are getting any power on the UPS or not. In case it is not working even on the AC power, then it might be the transformer inside the UPS which has burned. It can be easily repaired by taking it to any APC service center. This does not seem to be an issue with the battery since the UPS is not even turning on
Apr 29, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Hardware attack
Having similiar issues with the i6780. We are experiencing high percentage of hardware attacks/loss of encryption. Talked with ingenico support, they made reference to a known board issue, but i have not been able to get any details.
Jun 30, 2009 | Ingenico 6550 TERMINAL OPOS POWER SUPPLY...
Insufficient Runtime Available on Agent
If the UPS display is indicating runtime at 6 mins, and software is saying insufficient, seems like a communications issue. I'd try downloading the latest communication software for the UPS and reseating the communications cable at both ends, making sure no bent pins, etc. could be causing a comm glitch.
Jun 25, 2009 | APC Smart-UPS 1500VA Shipboard...
Can not power up
To my personal experience eMachine MB's dies a slow aggravating death. I have had 2 that went janky and would take about 15 power up tries to boot. Probably the situation you are in now.
Did the power supply you had go bad? I seem to recall a bit of an issue with some older machines in the 2k series that when the Power supply died it took out the MB with it.
Sep 28, 2008 | E-Machines eMachines Desktop PC
Screen is off
With the machine only being two weeks old, I would RUN not walk back to the store for an exchange. This is a hardware malfunction or failure, and there is no way that the machine should have done this in such a short amount of time. Just tell them that the machine froze, you shut it down by holding the power button down (there was no other way), and now it won't boot. Don't tell them that you left it until the battery ran out, a sudden shut down due to a dead battery can cause damage, and they may give you a warranty run around for that. If they give you any type of run around, demand a manager, then demand he/she give you an exchange. Don't take the run around and don't be afraid to get loud. Managers back down quick to a loud irate customer, they don't like other customers to think badly of their store. NOTE: If a machine ever freezes, and they will, you should shut it down by holding the power button down. It takes a few seconds, but the power button will override the system and shut the machine down. Most freeze ups are just due to software glitches and will start right back up, but in your case it's hardware, since the machine will not start up at all.
Jul 21, 2008 | MSI Computers & Internet
M120 will not power up - no lights, nothing
The Geek Squad at Bestbuy can do this. They are rather pricy though.
Jun 26, 2008 | Mirra M-120 (MIRRAPERSONALSERVERM120)
APC Smart-UPS UPS System Logo
297 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
