Question about Gateway FPD2275W LCD Monitor
Remove the back to an HP CRT Monitor
How do you remove the back to the HP P9605 17in CRT, Flat Screen Monitor. The monitor is dead and I want to check for a possibly blown fuse or open fusable resistor. Is there a special tool required or technique? I have removed all the screws from the bottom, and for the life of me, I can't figure out how to get the back off. I'm sure it must have been snapped together. I just don't know the points around the perimeter of the monitor. My kingdom for a maintenance manual. Please help if you can.
  • 44 Answers
First of all u have to tell me the way it's gone dead. is it damged due to excess power supply or in a running mode (suddenly). You have to tell me the major component used in power supply unit, only then i can give u the complete guidence and solution.
Posted on Feb 07, 2008
How to turn my 1080 hp monitor on connected to my computer
Look for the power button/switch on the monitor
Oct 13, 2017 | HP Computers & Internet
Have a highly distorted screen is there any way to possibly fix
This is a CRT monitor not a flat screen monitor?Yes?Must take the monitor aparts and must be plug in for power than take the video board out of the CRT tube(HIGH VOLTAGE AREA can give a very bad electrical shock so becarefull).Than this can be fix by only by a wire is grounded with a screw somwhere inside the monitor steal frame one end and the other end go toward the CRT tube(HIGH VOLTAGE AREA).Than u will hear a small pop,that good mean your monitor is clean and clear of build up of contaminations,Monitor now should be clear like the day you first bought it.If this a flat screen monitor the LCD screen is dead,must be replaced sorry.
Mar 17, 2013 | Computers & Internet
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
The screen is tilted
You can adjust the keystone of the monitor..
this will remove the trapezoidal shape and square up the image to the monitor.
Check on the monitor for the menu controls and you should be able to find the keystone adjustments... allows you to adjust the upper width, lower width, etc...
Nov 27, 2009 | HP Compaq FS 7550 17" CRT Monitor
HP Flat Panel Monitor is dead!
The power supply within the monitor has probably expired. HP doesn't do spare parts for their TFT monitors as they are Full Unit Replacement items (if in warranty).
Jan 25, 2008 | Computers & Internet
Cleaning monitor
I dont know which type you have but here is how to clean either:
CRTs
Those big chunky CRT monitors have glass screen which are easily cleaned. The important thing to remember is that you don’t ever want to spray any liquid directly on the screen. Instead, spray the cloth with water or a mild window cleaning solution then wipe the screen. You can use the same damp cloth to clean the entire monitor case, as well. If you prefer, you can also use moistened paper towels to clean CRT monitors, You will be only cleaning the outside of the monitor case and screen. Never open the monitor casing which contain electric voltage that can cause a shock.
Flat Panel LCDs
LCD monitors are often called flat panel monitors because they are flat and thin. These are the types of screens that are used in most laptop computers, and they are also becoming very popular for desktop computers. LCD screens are softer than CRT glass screens, so they require some extra tender loving care. Keep your fingers and sharp objects away from these screens since they are susceptible to damage and scratches.
Use a soft dry cotton cloth to remove fingerprints and smudges from the screen. If this does not completely remove the dirt and splotches, use a small amount of isopropyl alcohol on the cleaning cloth that has been dampened with water. (A small amount of vinegar can be substituted for the isopropyl alcohol.) Again, spray the liquid on the cloth and never directly onto the screen. Do not use paper towels on an LCD screen as they can scratch the screen. Never use ammonia, ammonia-based cleaners, or strong cleaners which can cause the surface to yellow and become brittle.
It is good to have a special clean cloth that is dedicated to use on the LCD screen. Don’t pick up any old rag, as dirt particles in the rag can scratch the surface of the screen. Special LCD cleaning cloths are available and can be an excellent investment.
Jan 04, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor problem
Check the cable wiring make sure all is plugged up right, If you have rebooted and it comes on ok than its the power cord. Remove and re-plug again
Nov 29, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
Dell 1703 FPi 17" TFT LCD Flat Panel
you have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Sep 06, 2007 | Dell 1703FPt 17" TFT LCD Flat Panel...
Gateway FPD2275W LCD Monitor Logo
146 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
