Question about HP DeskJet 810c InkJet Printer
Oops my printer fell off the table and landed upside down. The rod that hold the ink cartridge came loose and also the transparant plastic tape that I think connects at the same place as the rods. I can get the rod back in place, but where does the tape go?? It has small cutouts in the end that looks lide it attaches to something.
    Genius:
  • 3,587 Answers
Oops..that's not going to help out too much. I'd say that your printer is really going to need some professional onsite or depot help. Dropping any computing device will upset it's mechanicals dramatically.
Posted on Feb 06, 2008
How to identify genuine and fake toner supplies?
When buying ink cartridges, first of all to carefully observe the vacuum bag. Authentic ink cartridges and bags close to the box dense, no air bag. Fake and shoddy ink cartridges vacuum pumping is not complete. Open the vacuum plastic bags, genuine ink cartridges should be clean and dirt-free. Carefully observe the top of the ink cartridges sealed plastic stickers, real ink cartridges sealed film flat paste, fake ink cartridges loose, it is easy to hand down. Second, look at the sealing tape. Genuine ink cartridges and fake ink cartridges are not the same, fake ink cartridges is a transparent adhesive on the word, strong sticky, it is easy to tear the surface of the packaging cartons. Genuine ink cartridges are strong texture, sticky and sticky can not be separated from the carton to tear the way. I always buy ink and toner cartridge online, and I found v4ink is the best compatible toner supplies with good quality and low price.
Oct 31, 2017 | Genuine Office Equipment & Supplies
Transparent printer tape
It should be on the carriage. You may have to remove the top and side covers to gain better access. The inks are water soluble, so just take a damp cloth and wipe along the carriage.
Hope that helps.
May 05, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
How do i put in ink on 926 dell photo scanner and copier
From the online manual...
1. Turn on your printer.
2.Lift the printer unit, and then position the scanner support between the tabs to hold it open.
3.The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4.Press down on the ink cartridge lever to raise each ink cartridge lid.
5.Remove the old ink cartridges.
6.Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
9. Snap each lid closed.
10. Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
Manual can be downloaded here.
Oct 30, 2012 | Dell 926 All-In-One InkJet Printer
How to remove ink from printer
Ink Cartridge Maintenance
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
How to instal a new printer ink cartridge
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Mechanism, belt came off.
Turn your machine upside down and give it a shake. Most likely, a small spring will fell out. The same thing happened to us and sure enough, it was the spring. This spring will give the tension you need to hold the belt on the plastic piece.
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Plastic strip fell off
Hi, if you open the open the printer, unit to gain access to install ink cartridge, if you see the metallic end which has got a hook on both the ends left and right side. the ink cartridge runs between the strip from left to right which should be connected above the ink cartridge meta rod.
< ------------- >metal hooks on left and right above the cartridge rod
======= __ cartridge rod
Let me know for further info.
Feb 05, 2008 | Dell 810 All-In-One InkJet Printer
HP DeskJet 810c InkJet Printer Logo
Ben Johnson
