Question about Boston Acoustics BA735 Computer Speakers
My Speakers went out and now all I hear is a buzz.
CAn anyone help me?
Also I guess the plug in headphones jack works but in the backround i still hear fuzzy noises.
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there,
First things First:
1) Check cables for dust, or bad connectivity. Clean aprop.
2) Clean carefully the volume control inside, with spray for computer use.(carefully inside the conectors)
3) Finally and sadly, have to change the speakers, may be is something damage inside the board of speakers, or fried. :o(
good Luck
Posted on Feb 08, 2008
Hitachi 42 PMA400e Plasma Tv.
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
Mar 22, 2017 | Hitachi 42PMA400 42 in. Plasma Television
This is on a 15 watt Peavey Vypyr. I have a buzzing at the bottom end of my amp, when playing on the low E string. I plugged in my headphones and the buzzing went away while playing. I have also raised my...
The voice coil on the cube speakers must be scraping against the magnet.Or the speaker cone must be damaged causing it to flutter at low frequency where there will be large cone movement. Try removing the phono jack from your musical instrument/ guitar and touch the tip of the jack with your finger. You will hear a hum, now turn down the volume and listen to the speakers very closely and see if you can identify the flutter. All the same you will have to fix the speaker or replace it. Have you ever dropped the speakers, if so the speaker frame could have warped causing the scraping noise.
Aug 08, 2011 | Peavey Vypyr 100 Guitar Combo Amplifier...
Ok so 1 of my kidos has the RCA 20F420T tv, and i guess there is no headphone jack hole, so i went and bought adapter that plugs into the av jacks, still doesnt work can you please help!!!
Without knowing the specifics on this adapter - I can provide only provide some clues as to how this works.
Basically, the A/V jacks on a TV has a "fixed" audio output level - this means that the sound levels on the A/V jacks is NOT controlled by the volume control of the TV itself. You should be able to set the TV volume to minimum and then use the adapter's volume control to make the earphone / headphone sound louder and softer. Your TV however, may have a setting in the menu that can change the audio from "fixed" to "variable". If set to "variable", when turning the volume down for the TV's built in speakers will also turn the volume down on the A/V jacks as well. You do not want this to work like that as the sound in the headphones and the TV speakers will be same - instead of the TV speakers being off and the headphones on.
I hope this helps and good luck! Please rate my reply. Thanks!
May 26, 2011 | RCA 20F420T 20" TV
I have a Toshiba 46XV550 LCD TV. It has a headphone jack but this mutes the TV speakers when I plug in wireless headphones. Can I use another outlet (with an adapter) so the TV speakers stay on and I can...
I went to the local electronics store and bought one 2xRCA sockets-3.5mm stereo socket splitter and 2 RCA joiner/couplers and plugged that into the monitor audio plugs at the back of the TV. Works great for a total of $12.00.
Sep 14, 2009 | Televison & Video
Low sound in headphone
I would say it is because the unit does not have a built in amplifier. The speakers are powered PC speakers of studio monitors I am guessing. Try plugging the headphones into the headphone jack of the speakers if they have a headphone jack or try a set of powered headphones out of the Edirol and see if it helps.
That should remedy the problem.
Dec 27, 2008 | Edirol UA-4FX External Sound System
Dell 610 lptop - haedphone not working,
First try uninstalling the sound drivers from the device manager, then reboot. It will find and reinstall them, then check Dell's support site for updated sound drivers. If you find updated drivers you will need to use the update button for the device in the device manager. If this doesn't work, then it may be a faulty headphone jack. The jack should override the speakers when the headphones are plugged into it. If you can still hear the speakers with the headphones plugged in then the jack is faulty and needs replaced. If the jack does override the speakers or if you get some static then it could be that the jack has come loose or has a loose or broken wire. The only other thing is try a different set of headphones, sometimes laptops get picky and one set will work and yet another set may not.
Jul 02, 2008 | Dell Inspiron 2200 Notebook
I can't hear anything on my web cam
try plugging a pair of headphones into your headphone jack. I found out after many hours that some webcams ignore the built-in speakers if the drivers are not fully updated, so they rely on the computers main speakers.
May 22, 2008 | GE EasyCam Plus Webcam
No sound
turn your speakers up and moisten your finger. touch the jack plug that inserts into the pc, if you hear the speakers buzz/crackle then they are ok. If not I would try a new lead if possible, else speakers are u/s as if headphones work then speakers should as well as use the same output from the pc, just amplify it unlike headphones. You could also check in the cpanel to see if your speakers are set to speakers and not headphones but to be honest I cant see this stopping the speakers altogether.
Mar 22, 2008 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Sound is warped
Likely what happened is, in your efforts to get the piece out of there, you loosened a solder point on the headphone jack, and it will need to be resoldered. If you don't feel comfortable doing this yourself, you can send it to a technician who can.
Sep 15, 2007 | Creative Labs Zen Micro MP3 Player
Boston Acoustics BA735 Computer Speakers Logo
130 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
