Monitors
Problem for Monitors
Generic problem for all Monitors
Benq FP222W
By gadgarra on Feb 06, 2008
Every time I switch on, or the signal to the monitor changes, the message "Input D-sub" appears. This is very distracting. Is there any way to stop this?
Thanks
Don
Comments:
Feb 07, 2008
- I could not find "resolution", but I did find "refresh rate". The only avilable setting was 60Hz.
Same Problem
Apr 22, 2009
-   same problem with NEX multisync 1940CX. This is maddening ... I just have to hit the "select" button on the bottom left of the monitor to get it to go away every time my monitor comes back from sleeping, but very annoying-   Guest
Dec 10, 2008
-   Have The same problem,
frequency change does not help.
-   Guest
Solution #1
posted on Feb 07, 2008
Somewhat Helpful)
XxXShadowXxX
Rank: Apprentice
Rating: 70%, 4 votes
Try putting the resolution on 65hz if that dont work then try
different resolutions on the monitor. Right Click in a open area on your desk top and click properties and the click the monito tab to change the resolutions.
Comments:
Feb 07, 2008
- also i forgot to mention after you hit properties click the settings tab then under color quality hit the advanced tab on bottom right hand side this will allow you to change to what resolution you need.
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
how do i change the input to hdmi
Answer
i have a tv using a svidiod cable to connect and just got this provview and hooked it u and it did... (More)
Answer
princeton 19 inch LCD blinks and chirps. i need a manual for it ,plus i have anHP pavillion zd7310... (More)
Answer
I have a monitor model fpd1530 from gateway and when I turn on it says safe mode then goes blank
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Monitors:
Top Monitor Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
