Back to:
Tags:
Tasco 750 Monocular Microscope
Fixing one
posted by tractor man on Feb 06, 2008
How do you fix the wireing to the bulb
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 28, 2008
Not Rated (0)
endospores
Rank:Guide Guide
Rating: 85%, 6 votes
You must detach the bottom cover of the base of the microscope by taking off the 4 or 5 screws that keep it attached. That should reveal the wiring to the socket and bulb base.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on fixing one:
I don't want to Accept this solution
Can you Help with these Microscopes problems?
where can I find a manual for a kids Tasco 80X-1200X Zoom...
Microscopes
I replaced an old (failed - hours used up ?) mercury arc...
Microscopes
field does not change as mechanical stage is moved
Microscopes
I have lost the processing software CD for Galileo Mars...
Microscopes
My Vivitar 900x 28-piece microscope set (WIC#552844...
Loading problems.
Repair Service
Find Microscope Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
