Question about Itron Technology Scorpius P20 Keyboard
Scorpius P20 Receiver
I plugged the receiver into my computer and my computer didn't even locate it.
  • jmurraytoo Feb 22, 2009
    My Scorpius-P20 needs re-synched every time I start my computer. A real pain. The manufacturer will not reply to my emails. DO NOT buy this keyboard. While it functions great, the re-synch is ridiculous.
  • tobbe2008 May 25, 2009
    Have not been able to connect the keyboard even once.
I recently got a Vibe keyboard and mouse as a gift. Both are wireless and use one USB plug together. The model number is Kb-262. I can get the mouse to connect, but the keyboard will glitch and suddenly...
yer you are,switch the computer off, then plug in the keyboard & mouse...i'm thinking the GREEN ps2 port for the mouse & USB for the keyboard...
put batteries in them both,make sure their not dead batteries, then locate the little connect button on the bottom of them both, & the one on the receiver as well.
get a pin or something of the sort, so you can press these connect buttons.
switch the computer on, then once its booted up..press the button on the receiver @ the same time as the connect button on the keyboard,if not then the receiver first then the keyboard.
once connected, do the same with the mouse......receiver button then mouse connect button or both @ the same time...
you'll get it in the end,you'll need to do this ever time you change the batteries.
GOOD LOOK!
Sep 10, 2011 | Computers & Internet
My Sony receiver is an STR-DE675. The subwoofer stopped working after I moved the receiver, disconnected the cable and reconnected the cable a few times. I have changed the cable and used a different...
I didn't look up the schematic for this exact model, but many of these units have the surround amps on "cards" just like a computer has a video card or network card, and these can come unseated in a move. Open up the unit, and reseat any cards that are in the unit.
You can check fuses while you're inside the unit as well.
Jun 21, 2011 | Sony STR-DE675 Receiver
I need to replace the batteries to a cordless logitech mouse, where are the buttons located on the wireless keyboard to sync everything back up? And how long do I hold buttons for?
I used to use a set of these
the button on the key board should just be on the bottom, if you dont see it it might actually be in the battery compartment. but im pretty sure its just on the bottom it might even be red.
to sync it, have the receiver plugged into the computer and the computer on. push the button on the receiver until the little green light flashes on the receiver then press the button on the keyboard, the light should stop flashing and the keyboard should by synced, do the same with the mouse.
Mar 26, 2011 | Logitech Cordless Mouse
Scorpius K3NT USB Keyboard prevents resume after standby in Win2K
When entering standby, the usb ports go to sleep. Most motherboards allow you to tell the bios that you are using a usb keyboard. That should solve the problem. I keep an old ps2 keyboard plugged in and on the floor as a 'just in case'.
Jul 24, 2009 | Mini iOne / Qtronix Scorpius K3NT PS/2...
Record from turntable to computer via Pioneer SX-737 Receiver
Hi and welcome to FixYa,
Pls be informed that the model was not displayed, only the brand Pioneer.
Nonetheless and assuming that the turntable is built-in into the receiver, locate the REC out or LINE out at the rear of the receiver. Plug the RCA of the cable there while the 1/8 plugs into the AUX/LINE IN of the computer. Select PHONO in the receiver, in the computer, double click-on the speaker icon in the System Tray (clock). The speaker control window will open:
  • click on Options;
  • click on Properties;
  • tick/click Recording;
  • check Line in and/or Aux;
  • press on OK button;
  • adjust Aux/Line in setting to desired level.
It is of course necessary to likewise be running a recording program.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 20, 2008 | Audio Players & Recorders
Does not power on
you probably blew a fuse in the power supply
Feb 07, 2008 | Yamaha RX-V661 Receiver
Microsoft Wireless Optical Mouse - Probs w/Notebook Receiver
No there aren't. The power for the reciever comes out of the port it plugs into. My suggestion would be to replace the batteries in the mouse itself, or replace the unit.
Aug 02, 2007 | Microsoft Multimedia Optical...
Itron Technology Scorpius P20 Keyboard Logo
88 people viewed this question
Top Itron Technology Computers & Internet Experts
David Payne
David Payne
Are you an Itron Technology Computer and Internet Expert? Answer questions, earn points and help others
