Question about Frigidaire GLWS1233A Top Load Washer
Frigidare gallery washing machine
My machine stopped draining. i took the front off, and the belt is intact, mooving so is the tub. the hose is fine and there is a burning smell and a whine when in motion. please help
  • 1 more comment
  • shelby5 Feb 07, 2008
    Thanks for the help! It was an opened paper clip stuck in the pump. What a wet mess. But it gave me the opportunity to explore my washer.
  • mduff4 Nov 30, 2008
    I had the washer on normal wash and it was washing like it was a gentle wash and there was a funny noise. We found water on the floor as well.
  • robert samples May 11, 2010
    did you check the drain pump for a foreign object jamming it also check the spin tub to see if it will spin both ways and have you noticed any water on the floor
    President:
  • 1,314 Answers
Your welcome
Posted on Feb 07, 2008
Samsung helpline
Check for obstruction at the hose in the drum.
Aug 05, 2017 | Washing Machines
Not draining all the way
Hi and welcome to FixYa I am Kelly. Gently tip the unit to the rear and block it up on something solid so that the front of the machine is high enough up that you can reach under the the front of the machine. I use THREE 2x4" blocks nailed together with blocks under BOTH front legs. The pump is in the right front corner of the base. Grasp the pump pulley and see that it turns freely. You will also be turning the motor but that is fine. If it turns freely start the fill cycle and let it fill until there is about 8 inches of water in the tub. Have someone select spin and then WATCH the pump pulley. Make sure it is not intermittently stopping or that the pump drive belt is not slipping. If all of this checks good the next step is to drop the drain hose and see if the water in the tub will drain by gravity at a pretty good rate. If it does not drain rapidly with the drain hose below the wash tub with water in it then there is something in the bottom of the Tub blocking the drain hole. <br /> You will have to remove the front panel by remove the 2 phillips head screws near the bottom front corners. Then pull the front cover toward you for a little over 30 degress and remove the panel. There are spring 2 clips at the top of the panel your disengaging. <br /> Remove the TUB drain hose from the bottom of the wash tub and check in the hole for any obstructions. Next remove the hose from the top of the pump and check the pump impeller. Using both hands... one on the pump pulley and one finger in the pump top hole hold the impeller and turn the pump drive pulley. It should NOT slip. If it is slipping you will have to change the pump. <br /> That is pretty much it for trouble shooting a drain problem other than making sure the drive belt is ok. If you can not clear an obstruction then the top of the machine has to be opened and the inner wash tub has to be removed. I wil help you with that IF you end up with somehing between the inner and outer wash tub blocking the drain hole. Just respond here and I will get back to you. <br /> <br /> Parts diagram for pump Item 28 and washing machine: <a href="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45823">http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45823</a><br /> <br /> Thanks for choosing FixYa.<br /> <br /> Kelly <br /> <br /> <br />
Jul 07, 2010 | Maytag LAT2300 Top Load Washer
Frigidaire gallery washing machine and dryer combination flsec72gcs6 will not stop draining need to take out clothes in order to fill happens mostly on rinse cycle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Make sure the drain hose is not pushed too far down the drain pipe. It could cause a siphon effect and drain the tub.
Make sure the drain hose is not tight in the drain pipe. It should fit loose so as not to trap the air which can also cause a siphon effect.
Feb 22, 2010 | Washing Machines
Leaking from the bottom of washer
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem that you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. If that happens, the entire outer tub would need replaced, but that might not be an economical repair to make and would require professional assistance. Hopefully, the main drain line is leaking and can be repaired. Sorry for your trouble and I hope this helped. Best wishes
Sep 13, 2009 | Washing Machines
Tub will not completely drain.
try a hard reset unplug it for 30mins and try again
Jul 07, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
WASHER WONT DRAIN
Take off the lower panel ( 2 screws on bottom) pullout and down to remove. Make sure unit is unplugged pump is on the right hand side one hose coming from bottom of tub and the other goes out the back to the drain. Take off the hose from the bottom of the tub and be ready to catch alll the water in the tub suggest you use shop vac and remove all water first. look in the impellar in pump should be a clog right there then put everything back the way you toook it off and be careful to get the hose back on the way you took it off there is a slot in the hose and a tab on the pump for alignment.
May 30, 2009 | Frigidaire GSTF1670A Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Water leaking around machine
ck belt or replaced belt is designed to slip to a point if belt grabs too quickly the tub rpm come up to fast not giving tub time to drain down far enough to prvent climbing over the side also be sure drain hose is not plugged reducing water flow to drain
Jun 04, 2008 | Amana ALW880WH Top Load Washer
Frigidare gallery front loader modle #417.39012890
No. with the cost of the parts that you purchase it would almost like buying a new one., and besides the other parts is waring out.
Apr 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidare Front Load Washer dispenser drawer wont drain.
I think you have something stuck in the fill hose.. Remove the top two or three screws in the back.. then pull out the hose that goes to the tub. I bet you will have something in there.. most common is the inside liner to a bleach cap..let me knowif this it it... krazytech
Sep 08, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
130 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
