Question about Minolta magicolor 2300W Laser Printer
PRINTER COLOR The printer works - but the color is off - a greyish hew. Changed all the cartridges and the imaging drum - Still color is off
    Champion:
  • 214 Answers
There should be some quality settings in driver menu or status monitor, check these.
Posted on Feb 28, 2008
Message saying drum unit life on OKI PRINTER C510dn
This model OKI printer is not an inkjet printer, it is a color laser printer. and uses color toner cartridges.
The printer image drum unit has reached the end of its service life and this drum unit needs to be replaced.
I suggest you Google the Internet for an OKI image drum unit for your model printer, You will get various suppliers and their prices.
The image drum unit will cost approx. A$200
Feb 07, 2013 | OKI C5100n Laser Printer
Have an MD 1300. printer begins then stops before actually doing the job. Get message: "cartridge change error - cannot complete print job." I have tried putting in a new cartridge but same...
What color are the cartridges that you are putting in? Are they blue or are they greyish in color? If you are trying to print on laser or other such paper, you need to be using the greyish cartridges. Also make sure that the cartridges that you put in have plenty of ribbon in them and that you've put them in facing the correct direction, you should be able to see the color names when you open the printer. If you don't, you've installed them facing the wrong way. Also make sure that you have all the correct colors installed for the print job. Unless you're printing strictly in black and white, you'd be surprised at what colors are needed to make a color, unless you're using pure Cyan, Magenta or Yellow. Any colors other than those will need to use a combo of those colors to reproduce colors properly. I hope this helps. If not, write back and say what steps you've followed to try to remedy the error.
Nov 18, 2010 | Alps MD 1300 Thermal Printer
When I try to print on HP Color LaserJet 2600n. black color doesn't appear. I changed the cartridge but the problem still. I test the cartridge on another printer and it's ok.
The cartridge is missing contact from the drum to the ground. When this contact is missing, the charge from the the laser exposed areas on the drum cannot disappear and the result is lack of image.
Remove the cartridges and compare the connecting pins of the nest for the black with other nests. One may be bend and loosing it's contact.
Aug 20, 2010 | HP Color LaserJet 2600n Printer
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
Greyish marbeling on printed page & yellow wash allover page.
Sounds like you're probably running compatible cartridges. I sell a fair number of these cartridges to my customers, and it took a while to find a brand that actually worked. If you're seeing toner all over the place, the cartridges are most definitely the problem.
May 18, 2009 | HP Color LaserJet 2600n Printer
Black color on photos greyish looking and pixelated
Please check the Printer Setting Preference in for Best print.
And also try to work out with a new Cartridge. Let me know if the problem still persists.
Regards
Ellin
Sep 25, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Not printing
Black cartridge is low! That means you have a few pages to print but yellow is off! maybe you can change the chip on the BLACK and YELLOW cartridge!!!!
Oct 24, 2007 | HP Color LaserJet 2550n printer + HP Color...
Printouts with shadow
Two things - Fuser or cartridge - stop print halfway in machine, if fault occurs before paper has gone threw the fuser then it is a faulty cartridge, if print is ok before fuser (the hot bit at rear) but gets doubled up after fuser then the hear roller in fuser are faulty change fuser....but 95 % of the time it is due to dodgy refill cartridge or worn cartridge (the rubber blade inside cartridge fails to apply enough pressure against drum to clean away old image  hence duplicating itself onto your nice clean paper! Try a known good cartridge if in doubt..
Oct 16, 2007 | HP LaserJet 1300 Printer
Minolta magicolor 2300W Laser Printer Logo
47 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
