Question about HP Pavilion zd8000 Notebook
Randomly Shuts Off
My laptop is plugged in and it seems the AC power is fully functional. The most frequent times that it shuts off are when there is a CD inserted in the computer, or I am playing an online game, such as Guild Wars. I have no clue why this happens, and it is very frustrating. I am even using a Targus cooling unit, set under my laptop. Someone please help! My Pavilion zd8000 Notebook randomly shuts down when left unattended for any length of time. As long as I am working on it it will stay up, but if I step away just to take a phone call...CRASH! I lose my work I lose whatever I was working on.
It is really annoying.
I am thin king this could be a bios problem,
  • Roseworks Feb 13, 2008
    I do have XP and I went into my screen saver power settings as you suggested. I was not offered anything that said power saver (checked or unchecked), but I was offered settings for hibernating etc. that I had already previously accessed through Power Options in the Control Panel. I have been fooling with those things for days.
    I do think that the probelem may relate to the Screen Saver, because sometimes when the machine doesn't crash it will simply FREEZE on the screen saver. I then have to hold down the On/Off switch and crash it myself to get out. It won't let me go to the shut down screen.
    Thanks for your help,
    The three top apps. for CPU & Memory usage are:
    AZVENA.scr (CPU25,Mem Usage:54,688
    firefox (CPU=02, MU=128,112) constantly shifts while in use.
    svchost.exe (CPU=0, MU = 31,228)
    One thing I did that seems to have helped somewhat is that I uninstalled AOL Instant Messenger. I have nothing but problems with AOL software, and I always immediately suspect they are the culprit in times like these.
  • 689 Answers
Probably some applications in background taking excessive CPU resources. Please click on Ctrl+Alt+Del to open Task manager and go to Processes tab, locate sort the applications by CPU and Memory usage, and tell me top 3 for CPU and Mem usage so I can figure out next steps for you
Posted on Feb 06, 2008
    Genius:
  • 3,422 Answers
I think ur laptop goes to power saving mode.Right click on the desktop then choose personalize or properties if u have xp.
Then click on screen saver at the bottom click change power settings.Now if the power saver is checked then uncheck it and choose balanced in that change the timings as when it should sleep according to ur wish.
If u have any other problems please ask me..
Goodluck
Please don't forget to rate me as fixya..
  • Priya darshan Feb 13, 2008
    I suggest you to immediately remove the screensaver and the next thing is firefox it is using allot of memory try uninstalling and re-installing it or use the internet explorer.
Acer aspire switch 10 e, keeps shutting off randomly even when ac charger is being used
Is the airway clear to allow for good cooling? Bad connection on the RAM or HDD socket?
Aug 28, 2016 | Acer Aspire Computers & Internet
My computer shuts down when i plug in the charger
Assuming this AC laptop charger functioned correctly at one time. Several Possibilities: (1) laptop charger has failed ... connect another compatible charger to your computer to test for this; (2) or the battery has failed ... remove battery and test if the charger plugged in directly powers the laptop.
Apr 07, 2013 | Targus APA30US AC Laptop Charger AC...
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard
Jun 20, 2011 | Toshiba Computers & Internet
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
Power is erratic. Shuts off randomly.
it could be caused by a lot of things. isolate it first. since its randomly shutting down, try first in normal mode. does it heats up before it turns off, if yes its an overheating issue. you may need to replace fan or even motherboard of your pc. have you checked your battery? is it properly seated? or is the problem happening when your system is plugged with the ac adapter? try to check the power cable.
Apr 06, 2010 | Sony VAIO VGN-T350P/T Notebook
Randomly shuts off and takes many times to try to
Take out the battery and only have the ac adapter hooked up. If you can get it to turn on the first try then that means the battery is shorting out the motherboard.
If you do this and your still having power problems then that means the motherboard is starting to go bad on you and the motherboard would have to be replaced.
Jan 23, 2010 | HP Pavilion dv1000 Notebook
My Averatec 3200 turns of randomly...
Check the CPU and Fan/Heatsink assembly. I have a pretty good feeling that the CPU is heating up too much and is not being cooled properly. There may be lint or dust clogged in the fan. You can get access to this pretty easy by removing a few screws on the bottom panel that houses the CPU/fan.
Feb 20, 2009 | Averatec 3200 Notebook
Randomly Shuts Off
is it hot ?
if it is, it is overheating, try to clean the cpu fan.
Jan 19, 2008 | HP Pavilion zd8000 Notebook
Laptop shutting off
This problem has happened to me on several occasions. I found that the connector that you plug your power supply into on the motherboard gets loose. Not making a good connection and like you said needs to be re soldered. Before attempting this, stick a small screwdriver in there and see if it's loose. If it is, then EVERYTHING needs to come off to get to it. Not a quick project. I suggest you take pictures along the way just in case. Good luck!
Nov 13, 2006 | Toshiba Satellite M35X-S149 Notebook
HP Pavilion zd8000 Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
