Question about Acer AL1716 17" LCD Monitor
My AL1716 doesn not work in DOS
I have a laptop .Unfortunately, the screen was dead .So i bought a AL1716 monitor .The monitor work properly in Windows XP,but in does not show anything in DOS .I just found out this website .I hope someone will help me out this problem.Thanks
  • 77 Answers
Hi
The screen probably does work in DOS but the laptop doesn't bother sending it any signal in DOS, it's only when windows starts that windows takes control of the displays and shoots out a signal to the external monitor
I don't know how you would get round this because you can't see your BIOS which you need to go in to and set the primary monitor to external.
Posted on Feb 20, 2008
New laptop screen doesn't work
verify your ribbon cable didn't come unhooked when you set the new screen in, also make sure the inverter is hooked up properly.
May 06, 2012 | HP Computers & Internet
I have an acer al1716 monitor and since 2 weeks ago on the screen apears a box with the " input not suppported" message, then the pc shuts down. i may have changed the resolution settings and now...
the video settings on your computer has changed to a setting that the monitor doesn't like! try entering your computer in safe mod and change the setting to a max of 1024x768. however, if your video card has a dual output and you have 2 monitors connected at the same time then this is your problem. make sure that the 17" lcd is monitor 1 and the other monitor #2. one of the monitors is set higher the the 17" lcd and when it is not connected the computer may think this the setting for the 17" lcd and not the other monitor which may be hdmi or 1900x1080 which the 17" cannot read this it is out of range!
Aug 24, 2011 | Acer AL1716 17" LCD Monitor
3 horizontal lines at top of lcd Acer AL1716.Can it fix. Is it lcd driver or mother board problem?
in order to diagnose whether the driver or the LCD you should try to plug your LCD into other Computer, if the line still appears then the problem is the LCD, you might have a dead pixel
Apr 23, 2011 | Acer AL1716 17" LCD Monitor
Hi, i have AL1716 monitor (2 year old). Recently, there is a blue vertical line which appears on and off sometimes in the monitor. Can anyone suggest on a solution
Is the vertical line always at one location ? (on the screen)
If so, it appears that the video card/driver (on your PC or laptop) may be causing the line to appear occasionally ... i.e. flaky ... and it will likely fail (completely) in due time. To confirm it's the video card, try using another monitor (long enough) to see if it happens.
[ The line may also be caused by "dead" pixel on the screen ... but this usually happens on randomly located pixels on the screen, not on one vertical line. But, it may also be a possibility ... in which case, using a different monitor may prove it one way or the other ]
Aug 11, 2010 | Computers & Internet
Al1716 monitor plugged unable to change resolution.
You need to set the PC resolution to the native resolution of this ACER monitor, which is 1280x1024 @ 60Hz.
Mar 10, 2010 | Acer AL1716 F Monitor
Acer al1716 monitor flicks green and orange and screen remains black
I would say that is not receiving a signal from your computer.
Can you swap out monitors to see if another one works?
Most probably, if you see no error messages at all, you have a bad video card (assuming the computer is actually starting up).
Oct 21, 2009 | Acer AL1716 F Monitor
Acer al1716 dont work
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 03, 2009 | Acer AL1716 17" LCD Monitor
Acer AL1716 monitor
First of all check your monitor's color configurations using the buttons in the monitor. Then, if colors are set to default, go to your GPU's control panel, usually found by right clicking your desktop and finding an option that says ie. Nvidia control panel. Go to video control settings and/or desktop color settings and either restore defaults or configure them yourself if you know what you are doing. Hope that helps.
Jun 11, 2009 | Acer AL1716 F Monitor
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
Screen ajustment
Hi stefan,
You can adjust manually using the OSD (on-screen display) menu of you monitor by pressing menu button. Other monitor OSDs cannot be accessed on single button but some combination of buttons but considering it can be accessed, please look for it. Try also changing the properties at Operating System GUID (graphics user interface display) Control Panel Display or your monitors display monitor application software. Try changing the frequencies and other special features like single screen or wide screen, etc..
Best regards,
Rosener
Jan 30, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1716 17" LCD Monitor Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
