Printer problem We have a RICOH printer that will not print. We have reset the network, reset the printer, reinstalled the drivers. No dice. What is the problem?
  • cyanewt May 11, 2010
    model # ?
    Sergeant:
  • 390 Answers
What were you doing and what changes occured if any at time it stopped functioning. Cyanewt is right you have to provide more info for people to help.
Posted on Feb 10, 2008
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
Hello we have one printer Ricoh 2015 we want to connect to network printing . It is possible
In order to connect it to a network, you need to have the print/scan option installed. If your copier has the print/scan option, you can hook it up with an Ethernet cable and download the print driver from the Ricoh website:
http://ricoh-usa.com/downloads/software.asp?tsn=Ricoh-USA
May 29, 2010 | Ricoh Aficio 2015 Copier
I have a Windows printer set up for the Ricoh 12332C. Jobs are sent and clear the queue, but do not print. They appear to be accepted by the Ricoh - they show in the job history log, but they do not print...
Usually the setting of yout network with your copier/printer setting is mismatched so your printer.copier did not understand. What you can do you should check the system setting of your copier/printer and print it out then you should find the driver of your printer/copier in the add printer hardware secrtion in control panel of your computer network . Before you reinstall it , you should uninstall the previous driver so there is no conflict when you reinstall new driver . Try it
Apr 17, 2010 | Ricoh Aficio 1232C Color Copier
Use ricoh aficio 220 as network printer
If you have the print/scan option installed on the copier, just to go the Ricoh website and download the print driver, and you can use it as a network printer.
Feb 23, 2010 | Ricoh Aficio 220 Laser Printer
Can't print color or use finisher on our network ricoh from Mac
Sounds like you may not have the correct driver installed and also not configured right for devices
Dec 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I cant get my computer to find my scanner on my ricoh 2035
if you are adding it to your network... then you are doing ip printing... verify that nobody else on the network has the same ip address by unplugging the network cable from the copier and doing the following... goto start... accessories... command prompt... (black and white blox...) ping the copier... lets say ip is 192.168.168.168 then you ping it by typing ping 192.168.168.168 and hitting enter... if you get 4 time outs then ip is good... next step is to reinstall your print driver...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 08, 2009 | Ricoh Office Equipment & Supplies
Can not print to network printer
Do you mean you can ping it? If you can't, then disregard, my instructions below
You downloaded the latest "Vista" driver? then you went to"add Printer", Selected "Local Printer", then "create new port", select "standard TCP/IP port" typed in the proper Ip address of the printer? The wizard should find it and show it as using "Ricoh type C adapter" or similar, (if it moves on to the "select generic adapter" something is wrong) select have disk, and browse to the location of the unzipped printer driver, and install
Feb 26, 2009 | Ricoh Aficio 1035 Copier
Mac OSX 10.4.11 won't print to Ricoh Aficio CL2000n network printer
Okay, this is what worked for me...
1) Remove the printer from your printers by going to System Preferences, then click on Print and Fax.  Highlight the printer and click the "minus" button below it to remove the printer.
2) Reset your printer by restoring it to factory settings.  On my printer, you would do that by turning off the printer, wait a few seconds, hold down the two buttons on top of the printer, turn on the printer, then continue holding the buttons until the red "Alert" light begins to flash.  Then let go.  The printer will reset itself and then start back up again.
3) Go back to System Preferences and hit the "plus" button to add the printer.  When the next windows opens, make sure the "Default" button is highlighted and wait about 15 seconds for your printer to show up.
4) Highlight the printer, DON'T CHANGE THE NAME IN THE TEXT BOX, make sure the proper "Print using" driver is selected, then click "Add."
5) That should add the printer as your default printer.  Just make sure you don't change the name of the printer either in Leopard or by going into your printer's configuration utility.  Everything needs to remain as default!
With this printer, I used to try to change the name of the printer when I was setting it up to something more familiar like "Network Color Laser Printer" or something like that, but after about two days of working, it would suddenly not work printing from my Mac anymore (although the Windows computers could print to it without a problem).  Now, after leaving everything with its default name, my Mac always connects to the printer.
Anyway, just try it out-- what have you got to lose?
Aug 29, 2008 | Ricoh Aficio CL2000N Laser Printer
126 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
