Question about Dacor Preference RSD30 Gas Kitchen Range
Oven doesn't turn on, clock displays " :0 "
The only electronic button that does anything is the light button.
The last time this happened, which was about a month ago, I turned the breaker off and back on. This worked, but why did it happen again?
Is there a combination of buttons to press to reset the oven?
Please send me $30, to find out how!
Posted on Feb 12, 2008
Hyundai Elantra keeps dying despite my electronics being off.
Does the car crank slowly, or the starter clicks when you attempt to start it? If the alternator or voltage regulator is bad, the battery would continue to lose energy and appear to be bad. Alternators need to be fed voltage since they don't have magnets to excite the windings. On my Volvo, sometimes the indicator lights don't come on when I turn the ignition on, before actually cranking the engine. When this happens, I know from experience that the battery won't charge. Do you get any dash lights showing a problem?
You can check the voltage at the battery when the engine is running; it should be well over 12 volts if charging.
If a trunk, glove compartment or interior light is on, that can run the battery down too.
Nov 02, 2015 | 2004 Hyundai Elantra
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
Jan 31, 2015 | Heating & Cooling
We have Leviton push button slide dimmers w/the locate lights for power outlets and lights throughout our house. A couple of months ago one stopped push the button to turn it on and it...
Wiring is not best suspect.
If all the Leviton devices were installed same time, they may be failing at same time due to lifespan.
For example, ordinary on-off switch is a mechanical device with mechanical parts, and mechanical switches last many years longer than wiring devices that have electronic parts.
Electronic devices usually have standard 1 year limited warranty.
Jun 29, 2011 | Leviton Decora Light Dimmer Switch
I have a Jazzy1113,it had been unused for several years.I did not take right steps to take care of batteries. I tryed several months ago to start and of course would not,but i do remember some movement...
There is a 7.5 Amp ATO automotive fuse on the rear electronics tray that is probably burnt out. The ammeter will not work when this happens. Also, if you have a bad on-board charger that will inhibit movement of the chair. Unplug the on-board charger and see if you get it to move. Hope this helps.
Jan 04, 2011 | Pride Jazzy 1113 ATS Indoor Power...
All the lights are blinking when the door is shut but won't allow me to turn on. I have checked the power switch & reset my circuit breaker. Last time this happened (about a tear ago) Maytag instructed...
i have model number mdbd850awb and this exact same thing happened to me on the weekend. i fixed the problem by total chance! I depressed the "off" button for a few seconds and it reset the control panel, now it's working great... i hope this works for you and saves you some time and money!
Aug 26, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Unit Turns Off
Have you checked the breaker in the breaker box to see if it's tripped? Also check the amp rating on the air conditioner and the amp rating on the breaker the unit is plugged into, the breaker may be weak or not a high enough amps or rating for the unit it's trying to power.
Jul 01, 2009 | Friedrich QuietMaster RS10J10 Air...
Pioneer PDP-4330HD - turns iteself off - resets
I bought a 503 which had this problem, it would stay on for anything between 10 mins & 3 hours.
the guy told me he had been told it was a condensation sensor.
All I did was take back off, blow it out all boards with an air line, disconect fans. I ve had it 6 months now with not a single problem.
Jan 08, 2008 | Pioneer PureVision PDP-4330HD 43 in....
Powershot a610 will not power on
Junk in the usb mini connector could be shorting the main board out. Try a can of electronics duster in the port. Cheers!
Aug 13, 2007 | Canon PowerShot A610 Digital Camera
Dacor Preference RSD30 Gas Kitchen Range Logo
177 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
