Question about Kodak EasyShare C875 Digital Camera
Battery door Door won't close all the way. It won't slide closed far enough to latch. It doesn't matter whether batteries are in or if they're not in. This condition occurred without any prior signs of difficulty.
This happened to me just now too... Kodak wants $175 to repair it. If you look near the hinge, you'll notice a small (at least I did) metal clip-like structure that is blocking the door's ability to slide back. I believe this clip tells the camera that the door is closed. I believe the clip is bent. If you straighten it, problem should be solved, methinks. I am needing to open this camera to solve this problem.
Posted on Feb 13, 2008
Hi my name is jack i have a Kodak z981 easy/s .The battery latch would not close, this has been a recent problem
Jack, I have a Z981. When I examine the battery door, it appears to have two places where the door latches when you slide the latch to lock it. It may be that one or more of the metal tabs that fit into the two places to secure the battery door has become bent.
I cannot get the battery door latch to move if the door is open, but you should have no trouble identifying the two metal tabs that are used to hold the battery door closed.
Jun 22, 2017 | Kodak Cameras
POWER SLIDING DOORS WILL NOT RESET OR LATCH
I don't think this is a power problem at all on this. I think you have a control board that has gone bad. The board is usually part of the switch on the door. I assume these are both controlled on the drivers side door armrest. Sometimes cleaning and reconnecting is enough but replacement is the best option.
Oct 05, 2014 | Honda 2002 Odyssey EX
Drivers door will not latch closed
It appears that the door is not closing far enough for the latch to move to the second position in it's movement. ie on not closing the door properly you will see that it is latched but not closed . Push it harder and it closes properly. Lubricate the latch mechanism and you may have to adjust the catch position to allow the lock to go to the fully locked position POssible rubbers to cold and stiff to allow the door to close easily
Feb 03, 2013 | 1997 Ford Escort
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
  1. Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
  2. Manually open the power sliding door completely.
  3. Manually close and latch the power sliding door.
  4. Turn the power sliding door ON/OFF switch to the ON position.
  5. Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
  6. Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
Sep 30, 2012 | Chevrolet Vehicle Parts & Accessories
Ge nautilus dishwasher 165d5450p004 latch won't close
RoselsRose,
Thanks for the info about your grandson coming bye the dishwasher and messing with the dial! My son (14 month old) did the same thing and the soap dispenser door/latch would not stay closed. It just kept springing back open. I thought for sure the latch was broke until I saw your post and went to the outside dial and brought it back to off. Sure enough, the soap dispenser door stays closed. You just saved me an expensive repair! Thanks!
Sep 26, 2012 | Dishwashers
Door on 95 geo metro 4 door won't close because the child proof lock in on and I can't get it to go off. Door won't stay shut. Any ideas how to fix this?
Your childproof lock have nothing to do with the latch not closing. It only makes it where you can not open the door from the inside. I would think you are in need of a new latch.
Feb 12, 2018 | Geo Metro Cars & Trucks
I have a rope stuck in the door latch of a 2009 Kia Rondo, and the door is closed, so won't open from the inside or out. Is it possible to get the door panel off while it's closed? Or slide...
You might be able to get the top part of the cover off but I don't know haw much room there will be to get at the latch. You will have to be careful so as not to damage the cover.
Sep 04, 2011 | Kia Rondo Cars & Trucks
Door will close but latch will not lock
Try and check the latch in the door sometimes they catch and don't open all the way it may take a screwdriver to pry it up or it could be a clip has broke inside the door on the trip mechenizm and won't let it hit the spring tension to lock it shut.
Dec 16, 2008 | 1999 Oldsmobile Silhouette
Battery door doesn't close tight
Usually part of the plastic battery door breaks off so the sliding latch (when you push the battery door in toward the camera after replacing batteries) can't latch. If this is the problem you can buy a new battery door that will come with a new latch that isn't broken.
Jul 10, 2008 | Cameras
Kodak EasyShare C875 Digital Camera Logo
51 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
