Question about HP iPAQ HX2415 Pocket PC
BLANK LIT-UP SCREEN
Last year I spilled coffee on the screen of my IPAQ hx2415. It would come on, start to reset and begin with where you use the stylus to go through the calibrating procedure, but would not respond to the stylus. I sent it to elaptoprepair(.com) and they said it needed a new motherboard for $150.00. Since I could buy a good used IPAQ for that price on e-bay, I told them to just send it back to me. I got it back 2 months later and one day I just tried to turn it on. It came on, the screen lit up, but just a blank screen (I tried soft reset, hard reset, all of that). It was right by my laptop and I noticed that my laptop was telling me another computer was nearby, detected by the infrafred. It was the IPAQ, and it started to sync. I was able to explore it through Activesync and everything was there - Windows, files, etc. I don't understand how the motherboard can need replacing when it appears to be there when connected to my laptop. MY DILEMMA is this: I am willing to spend the $35.00 or so that I can get a screen assembly replacement for on e-bay, but that's all it would be worth spending, but I don't know if it IS the screen. By the way, it appears to have been thoroughly cleaned too - I saw no evidence of coffee on it (?). Can you tell if this sounds like it needs the screen replaced? Or can the motherboard be shot even though I can get into it via ActiveSync and everything looks normal? This just doesn't make sense to me.
  • pencho Feb 11, 2008
    I have a similar problem but without the spilled coffee. The screen just stopped working. I can use the control buttons but the screen does not respond to the stylus. I have both hard and soft reset the device to no avail. I can connect to my computer through activesinc. Can some one help me?
Can I ask, did you have any problems with the company, elaptoprepair.com?
I have read things and i wanted to make sure this was a real company with solid service and not a scam. I have read some people complaining that they did not get their laptops back and there were double charges on credit cards. I just want to know if you found this to be true and what your experience with this company was.
Alex Van Name
alexvanname@hotmail.com
310-295-8915
Posted on Nov 28, 2008
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
When I connet the Ipaq 2490, teh screen lights up
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Oct 13, 2009 | HP iPAQ HX2490 Pocket PC
I'm running Vista and I'm having trouble with my HX2415.I have Windows Mobile Device Center Installed. When I plug the unit into a USB port it doesn't find the hardware. It worked fine on XP with Active...
Hi
Thanks for using FixYa. HP ipaq HX2415 is compatible with Windows Vista Mobile Device center Version 6.1. Please check if you are using version 6.1, you can download the Windows Vista Mobile Device center Version 6.1 from this link--
Windows Vista Mobile Device center Version 6.1 Link
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 07, 2009 | HP iPAQ HX2415 Pocket PC
Hx2415 stuck on align screen
i think you have a problem with you touch screen digitizer. you can send your device to a repair center to replace the TP only, without the need od replacing the entire LCM display panel.
A touch panel withou the lCD should cost much less than an LCD.
Jul 30, 2009 | HP iPAQ HX2490 Pocket PC
My ipaq hx 2415 will not go past the ipaq screen reset screen
Have you tried a hard reset (deletes everything)
2. While holding down these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
Mar 18, 2009 | HP iPAQ HX2415 Pocket PC
Loaded with programs I dont use and need to know how to delete
To remove unused programs go to Remove Programs
(start -> settings, system tab)
Dec 18, 2008 | HP iPAQ HX2415 Pocket PC
BLANK LIT-UP SCREEN
In the future, whenever you spill liquid on something electonic, unplug it immediately. If there was no electricity going through it at the time, you can usually let it dry for a day or two, and it should still work.
Aug 10, 2008 | Cingular Wireless Cingular 8525 Smartphone
Screen not responding to stylus
SOLUTION:
KEEP PRESING CALENDAR+MAIL+POWER BUTTON
AND INSERT STYLUS IN RESET BUTTON
Nov 26, 2007 | HP iPAQ H1940 Pocket PC
Rz1715 continually reseting
Charge it overnight then do a hard reset... You will lose any data or files that you have added, but if a hard reset doesn't fix it, you should return it to HP...
Sep 07, 2005 | HP iPAQ RZ1715 Pocket PC
HP iPAQ HX2415 Pocket PC Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
