Acer AOpen AK77 Pro(A) (91.89A10.104) Motherboard Logo
Posted on Jan 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 p
Will not run xp pro i'm stuck in 2000 mode my mother board is ak77 pro 133 vt8233 will not run xp proI
have tried to install on a fresh disk, but the motherboard does not seem to recognize xp pro. I did check with the company I worked for who gave me the computer and they said that motherboard probably would not run xp. Is there anything thing that can be done?
Anonymous
Level 2:
New Friend:
  • Expert 57 Answers
  • Posted on Jan 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
57
Questions
0
Helped
18174
Points
165
Have you tried updateing the bios ?
Mother board is ak77 pro 133 vt8233 will not run xp proI
The BSOD (blue screen of death) usually means that a computer component has failed. This could be a hard disc drive, a memory module, the cpu, or the motherboard. I would start by checking out the hard drive first. See if it is spinning and not making any clicking sounds. Try replacing it if you have another one. Then check memory and cpu. Some people actually like having an old computer hanging around. They install Windows 98 in it so they can play old dos games and games that don't require a blazing fast processor! Good luck...Hank
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
1helpful
No sound after i update my os to xp pro svc pack2
Looking at VIA's page on the P4M266 and scrolling down, it shows you're using South Bridge VT8233/8233A/8233C. Going to VIA Arena and selecting XP, Audio, and VIA AC97 codecs incorporated into VT8233, VT8233A, VT8233C, VT8235 and VT8237/R South Bridges takes me to the audio driver you need. Just click the above link and get it.
I just installed xp pro and it keeps freezing
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
3answers
Version mother board?
This should be the drivers for 90% of the P4M Boards .
http://drivers.softpedia.com/get/MOTHERBOARD/Others/Via-VT8231-VT8233-VT8235-VT8237-Motherboard-36.shtml
Trying to install windows xp pro but its saying it cant find wmiadap.ex what is this and where can i find it?
Were you running 98 befor? As most pc's with 98 running systems won't run xp. Mother boards are to slow for xp.
1helpful
7answers
Graphics driver
VT8233/A AC'97 Enchanced Audio Controller
USB 2 support on Gigabyte GA-8PE667 Pro mother board
go to bios set up...check if ur usb is enable... then exit..save settings
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
