Question about Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL 5 Router
Contivity 1100 not get folders for FTP timed out
Does anyone have any idea what could be blocking ftp on my contivity 1100's?
4 Suggested Answers
  • 128 Answers
SOURCE: Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address (192.168.0.1) in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Posted on Feb 16, 2006
  • 137 Answers
SOURCE: Cannot access FTP server from outside.
your server need to connect on Internet with pubilc IP or fixed NAT with public IP
Posted on Apr 09, 2010
  • 3940 Answers
SOURCE: hot to reset password on contivity 2700 vpn router
see if this helpshttp://blog.michaelfmcnamara.com/2008/09/nortel-vpn-router-configuration-guide/
Posted on Sep 26, 2011
Nortel 1050 and BSR222 VPN Connection
1.  What you have is a "software settings" in several  locations that require "exact entries".  Without us seeing what  "entries" are being asked by the programs or what data needs to be inserted by the routers at each location, there is no way anyone could possibly solve your problem long distance.
2.  The basic generic information was supplied to you at another website you visited but obviously did not help you.  I appreciate you having the confidence by asking anyone here to guide you but I think you need to have some one physically there to fix the problem.  If someone here knows the answer and can solve this problem by all means jump in.
3. My solution is for you to look in the yellow pages for your town where you live under "networks" or "computer networks".  Some one locally should be able to come out and solve this for you.  VPN networks at this level require a "hands on" solution unfortunately and not a "cook book" answer.  Get one field wrong, you will spend days troubleshooting it.
This is the best solution for your problem in this case.  Anything else would be a great disservice to you.
Oct 23, 2007 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
Scan won't send the files to the network folder
1 - If connecting via the IP adress, please check that the IP address for the destination's folder hasn't changed (if it is an automatic ip address, i'll recomment placing a fixed one,
2 - Check the folder's permissions, you can try to allow anyone for that folder, write and execute for all users.
3 - If you transfer files via the FTP protocol, then you should enable file sharing with the ftp service active (port 21):
Thias is what i have found for windows xp:
"XP includes a built-in FTP service component that lets FTP clients connect to the machine and read or write files; however, this service doesn't install by default. To install the FTP service, perform the following steps:
- Start the Control Panel Add/Remove Programs applet (go to Start, Control Panel, then click Add/Remove Programs).
- Select Add/Remove Windows Components.
- Select Internet Information Services (IIS), then click Details.
- Select the File Transfer Protocol (FTP) Service check box, then click OK.
- Click OK to close all dialog boxes."
hope these things help
Dec 19, 2010 | Toshiba e-STUDIO 4511 Printer
I want compaq presario 700 motherboard driver
ALL THE DRIVERS U'LL EVER NEED FOR COMPAQ PRESARIO C700
(VGA) Driver:
http://downloadmirror.intel.com/13300/a08/win2k_xp1429.exe
Chipset Driver:
http://downloadmirror.intel.com/13499/a08/infinst_autol.exe
Wireless LAN Driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34152.exe
ALPS Touchpad Pointing Device Driver:
ftp://ftp.hp.com/pub/softpaq/sp31001-31500/sp31075.exe
5 in 1 card reader driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33604.exe
HP Quick Launch Buttons
ftp://ftp.hp.com/pub/softlib/software8/COL18360/ch-47422-1/sp33258.exe
LAN Driver
ftp://ftp.hp.com/pub/softpaq/sp30501-31000/sp30580.exe
To install audio / modem drivers, first download and install Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp32646):
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Conexant CX20549-12 Audio Driver for Microsoft Windows XP (sp36090.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
This will create a swsetup folder in C drive ("C:\sp36090")
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\sp36090 folder and select the .inf file (CpV30D5a) and click open and Continue with the onscreen instructions.
Conexant CX20548 Modem Driver for Microsoft Windows XP (sp36089.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
Download and install Conexant modem driver (sp36089). This will give error message and also will create a folder C:\swsetup\sp36089 which contains extracted driver files.
The same method which is used for installing audio driver needs to be followed for modem.
Sep 07, 2009 | Computers & Internet
No audio output installed
(VGA) Driver:
Chipset Driver:
LAN Driver
Sep 06, 2009 | Compaq Presario C700T Notebook
Problem with wireless router and Nortel VPN
Please remove any VPN You have, and just start your InterNet normal, go to Network Places, click on "create new connection" - Connect to Internet at my workplac (VPN... etc,) - Next - "use my internet connection" - address: vpn.kongshare.com
then next - next - finish.
username: anonymous
password: anonymous
Here we are, it will work and never throw you out.
Please send me your feedback to rabih_2@hotmail.com
Mar 22, 2009 | Nortel Contivity VPN Switch 1600...
High definition audio bus driver software
Here are the drivers for C770tu.
Video:
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38326.exe
Chipset:
ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36880.exe
Realtek RTL8100CL/RTL8110Sb NIC Driver
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38329.exe
Wirelsss Driver:
http://www.atheros.cz/download/drivers/ar5xxx/xp32-5.3.0.56-whql.zip
or
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/ar5xxx|_6038|_xp.zip
After downloading the file please extract the files to a folder on the desktop.
Follow the below steps to install the driver correctly:
1. Click start -> Select Run -> Type devmgmt.msc -> Click Ok. and right click "Atheros Wi-fi adapter " or " ethernet Controller" and select update driver.
2. Select "Not at this time", click on next and Select "Install from a list or specific location"
3. Click Next. Then select "Don't search, I will choose the driver to install".
4. Click Next and then select "Network Adapters" from the list.
5. Click Next and then click Have Disk.
6. Click Browse, Choose the location where you have saved the extracted folder.
7. Open the folder and choose the .inf file listed.
8. Ignore any errors you receive and proceed with the installation.
Quick launch:
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39425.exe
Alphs Touchpad driver:
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38629.exe
Card reader Driver (Ricoh 5-in-1 Card Reader):
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38330.exe
This model of Presario has an audio controller that supports the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio installed on the computer before installing the audio driver.
Here is the link for the Microsoft Universal Audio Architecture driver that need to be installed before installing the audio driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
After installing the UAA driver reboot the notebook and install the audio driver from the following link:
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/Audio%20driver.zip
3. Select not at this time, click on next and Select "Install from a list or specific location".
7. Click Browse, Choose the location where you have saved the extracted folder.
8. Open the folder and choose the .inf file listed.
9. Ignore any errors you receive and proceed with the installation.
Similarly install Modem Drivers form the link below:
Installing this driver may result in an error. But continue with the following steps to get the Modem driver installed correctly.
2. Right click on "Modem device on High Definition Audio Bus" and click Update driver.
3. Select "Not at this time", click on next and Select "Install from a list or specific location"
5. Click Next and then select "Modem" from the list.
7. Click Browse C:\swsetup\sp33089 folder and select the .inf file and click open and Continue with the onscreen instructions.
Sep 11, 2008 | Compaq Presario 700 470024-192 Notebook
How can i get the 4th hokage of naruto 3?
you cant because u have to beat the story mode to date hanabii hyuga.The fourth only shows up when everybody else is unlocked.
Feb 13, 2008 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Open Questions:
Nortel 1001s secure router qos configuration i have a nortel 1001s secure router i would like to configure qos on it i managed to managed to configure qos but it seems not to be working as when i try to calculate or monitor my bandwidth i seem not to get any data, here is a view of the running config of the router R-KEN-BITU-001 > sh run Please wait... (up to a minute)module serial 1 cable_type v35 clock_rate 2000000 crc 16 mode dte clock_source line data_mode normal exit serialinterface ethernet 0 description "Bitumen LAN" ip address 10.113.250.254 255.255.255.192 mtu 1500 qos exit qos exit ethernetinterface ethernet 0.1 description "Nortel Phones" ip address 18.113.119.4 255.0.0.0 exit ethernet interface ethernet 1 description "KDN link to HQ" ip address 172.16.18.2 255.255.255.252 mtu 1500 qos add_class NortelRTP root-out cr 40 br 128 add_class NortelDATA root-out cr 88 br 128 class NortelRTP add_src_ip 172.16.18.0 255.255.255.192 exit class class NortelDATA exit class enable policing outbound enable policing inbound exit qos exit ethernetinterface bundle Bitumen exit bundleinterface bundle bitumen exit bundle hostname R-KEN-BITU-001log utctelnet_serverssh_server exit ssh_servertelnet_banner banner1 "TOTAL KENYA LIMITED" banner2 "BITUMEN PLANT" exit telnet_bannersystem display-boot-config noip load_balance per_flow route 0.0.0.0 0.0.0.0 172.16.18.1 1 dhcps pool Total-Bituen exclude-range 10.113.250.244 10.113.250.254 exit pool pool Total-Bitumen domain total_kenya_hdq.com dnsserver 10.113.118.5 tftpserver 10.113.255.39 netbios_name_server 10.113.118.5 lease 604800 network 10.113.250.192 255.255.255.192 default_router 10.113.250.254 commit exit pool interface ethernet0 enable exit dhcps exit ipfirewall global algs exit algs max-connection-limit self 2048 exit firewallfirewall internet exit firewallfirewall corp policy 1024 out permit exit policy exit firewalltftp_servergui enable exit guisnmp-server snmp-enable community bituro ro community biturw rw location Bitumen-Plant chassis-id R-KEN-BITU-001 trap-version 1 exit snmp-server please assist in any way as im being fried on this... please thank you
Oct 29, 2008 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
See all Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL 5 Questions
Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL 5 Router Logo
Top Nortel Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
J John
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
