Question about GoVideo VR3845 DVD Recorder/VCR
Degraded Signal quality
Sir:
Have a GoVideo DVD player, & using RG6 coax, the signal is degraded, causing the picture to be fuzzy.
When I bypass the DVD player, the picture is clear, so the signal strength is good.
Is Govideo out of business, & can you help me?
Sincerely,
Randall Lindsey
  • Ranlin Feb 06, 2008
    Will run out & get an S video cable right away, & thx
    Dear Nick,
    Will go to Fry's Electronics & get the S video cable, have no idea what coupunt or HDMI are, so have printed this page to take w/ me.
    Thx again,
    Randy
    Master:
    Sergeant:
  • 440 Answers
U would need a s video or coumpunt cables going into it
Posted on Feb 06, 2008
  • nick helpap
    nick helpap Feb 06, 2008
    ya dont use yellow cables old ugle looking s video is better and coupunt best and hdmi is very bestthey make but yours needs s video cable thx nick
  • nick helpap
    ok hell tell ya thx again
Picture quality has suddenly degraded
Some time you get a bad one out of the store,still under warranty period.Yes best just return it to the store get a new one or get some store credits buy another one.Tried research if this brand and models of tv you have this problems happen to it more than the other tv brands out in the market.Tried to proof it to Samsung to get a replacement from them.U tries other incoming live tv broadcast make sure it it not the tv station signal or u tried tv with other media devices like BLURAY or DVD players see u have the same problems correct.
Jan 05, 2013 | Samsung 46" Full Hd Led Lcd Slim 1080p...
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
Jul 22, 2008 | Televison & Video
PPM4253Q fuzzy picture
check to see if using a DVD etc to one of the rear inputs you have the same problem--if so it is the set---if not and connected via the coax fitting it may be a loose cable, a defective box, etc feeding the signal.
Using a rear input could bypass this problem if it is not working.
Mar 30, 2012 | Samsung PPM4253Q Television
I have a pincushion problem on the screen , what causes this and how can it be fix?
Not sure what a pincushion problem is? If you mean it pixalates and/or seizes up, runs, you may need to re-peak the dish signal by repointing it, reinstall the dish, if trees or something else is partly blocking signal to the dish. Some transponders on the satellites are much weaker than others. Check signal on the transponder you have the most problems, go to install satellite to check signal. Even rain and snow on the dish or in the air can degrade the picture. Another problem can be caused by used old cable tv wire to bring signal in for the dish. Newer receivers require much more bandwidth that requires good quality RG6 cable coax wire. Even roosting birds can cause problems.. Make sure there is no snow on the dish.
Feb 11, 2011 | RCA Televison & Video
When I try to use my DVD player it says "Unusable signal" on my screen
In most cases, this error message is caused by bad cabling or connectors. - It is receiving some kind of signal, but a likely degraded one.
Dec 19, 2010 | Televison & Video
We live in ireland and we bought a dvd on amazon but it says ntsc, we have dvd player and xbox, help
NTSC, known to us as Never Twice the Same Colour due to the way the picture is made up will not play on a PAL player. The NTSC format uses a 60Hz frame rate at 525 lines resolution and 15KHz line speed and the UK system is PAL usind a 50Hz frame rate and 16.250 KHz line speed. Pity as some DVD players will play NTSC Movies in "Simple PAL" but somewhat degraded picture and sound quality.
Hope this clarifies your situation.
Oct 28, 2010 | Computers & Internet
Are you truly free? If so, then answer the
Hello. Your digital TV is all set up to recieve the digital signal that is now the standard signal coming into your home. The old analog signal is history. If you still want to use your VHS/DVD recorder you will have to get a signal conversion box, at your local walmart or radio shack. This will take the new digital signal and convert it so your old analog VHS/DVD can process it properly. Joe
please rate my answer as very helpful....and free. thanks. Joe
Apr 26, 2010 | GoVideo Go Video DVD/VCR Combo
Faulty tevion lcd 32
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degradation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem.
  4. Open OSD to adjust the picture: Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed. If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
May 25, 2008 | Televison & Video
Picture problems
This could be an unshielded cable problem. Also magnetisam from speaker(s)(i.e. subwoofer) could affect signal from satelite antenna, or could affect satelite receiver if it's near.
Oct 01, 2007 | Panasonic SC-HT40 System
GoVideo VR3845 DVD Recorder/VCR Logo
63 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
