Question about Smith Corona Wordsmith 200 Typewriter
My keys have locked. How do you unlock them?
I don't know how or why the keys have locked... any suggestions?
  • reteng Apr 05, 2008
    none of my keys are working but the power comes on. is there anything I can check?
  • Anonymous Jul 08, 2008
    My ink cartridge was not secure, when I secured it, magic!!!
  • 168 Answers
If any of the keys are stuck in the down position, it will lock out the entire keyboard so that none of the keys will work.
One think you can try, is turn the typewriter upside down, and hit the bottom of the unit (right above the keyboard). See if there anything that falls out besided dust. Also hit ALL of the keys. Each and every one of them just to make sure non of them are stuck down.
Try this a couple of times, and see if it helps any.
Good luck.
Posted on Feb 06, 2008
Expedition door lock
Replace the battery on the key fob! Also, it may need to be reprogrammed by the Dealer!
Dr. Gene n Landrum
May 19, 2013 | 1999 Ford Expedition
I changed battery in the remote with a cr2032. The remote lights up but the doors still don't unlock. any suggestions ?
read qowners manual for exact number of times... but put key in ignition turn on and off between 7 and ten times..... locks will actuate! hit lock button on remote... remote is then set
Jan 29, 2013 | 2005 Chevrolet Equinox LS
Simlock unlock reset key
I don't know if this is the same problem, but you can try with these guys : www.samsungimeiunlock.com .Maybe they can help
Sep 12, 2012 | Cell Phones
Door locks on my jeep patriot 08 don't work.
First I suggest check fuse burned.
Aug 24, 2012 | 2008 Jeep Patriot
Don't know how to set key pad lock
Before locking the keypad first remember if the keypad lock is assigned with a security code.
Default value of the security code is normally 0000.
1. To lock the keypad first press the option key, then select the LOCK KEYPAD.
2. To unlock the keypad press the option key then press the "C" button.
You can check more lock/unlock optoons in the users manual, downloadable from this link. Read page 63 and on.
http://dl-www.sonyericsson.com/cws/download/1/150/669/1192984731/J230i__UG_R1a_EN.pdf
Sep 04, 2011 | Sony Ericsson J230i Cellular Phone
I locked my only key in my car. I just recently got it and do not know the unlock code. Isn't there a factory unlock code I could use?
I don't know if they have a code, but the dealer can make you a key you just have to show your registration.
Jul 25, 2011 | 1997 Mercury Sable
My key fob will unlock all my doors but my driver side door. Any suggestions?
if you can lock and unlock all the doors except the d-side and you can manually unlock and lock it with the key and the switch on the d-side door will not lock or unlock it then it is most likely the d-side door lock actuator and the only way that on most models you can get this part is by buying the door lock assembly...........this is a common problem on all makes and models........let me know if this was helpful and what you found out............good luck and if i can you in any other way let me know........
Jun 19, 2011 | 2007 Toyota Tundra
My Luxpro psp511 ca is locked and I don't know how
TO LOCK THE KEYPAD: Start with the System Mode switch in either the
HEAT or COOL positions, and the Set Slide switch in the RUN position.
Perform a single press of each button, in the following sequence: NEXT,
NEXT, NEXT, HOLD.
TO UNLOCK THE KEYPAD: Start with the System Mode switch in either
the HEAT or COOL positions, and the Set Slide switch in the RUN position.
NEXT, NEXT, HOLD. The padlock should no longer be present, with the
thermostat now unlocked. If the padlock is still on the screen, please try
to enter the 4-button sequence again.
Jun 01, 2011 | Heating & Cooling
I have a problem with a juki 5550n-7 the panel cp 160 shows a key buet I don´t know where to remove that key the whole machine turns on just fine but it does nothing just shows every thing but it does...
hi there
to unlock key on panel cp-160 please turn off machine and press start bartack button and first + button together and push power on. machine unlock
best regards
ashraf abozid
aabozd@hotmail.com
Jul 28, 2010 | Sewing Machines
Smith Corona Wordsmith 200 Typewriter Logo
580 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
