Question about HP Color LaserJet 2600n Printer
HP Printer problem
My HP 2600n printer has begun leaving large "Ink" smears on pages when printing in color. It is also leaving shadows of letters, etc. from previously printed pages. These problems happen intermittently, but frequently, and there seems to be no continuity to under what circumstances this happens. I've tried cleaning it with the cleaner sheets you can run through printers, but that had no impact. Any thoughts?
  • 6 more comments
  • ednkat Feb 06, 2008
    The drum is integrated into the color cartridge, correct? So I should replace the cartridge for the color of the double image? Would the inky smear be caused by the same problem?
  • jamahn Feb 07, 2008
    I have a similar problem in that it only streaks on one side and kind of shadows itself. what to do?
  • bigace Feb 08, 2008
    I get a reprint of the letters on the right side of the page. It is worse sdthe first time I print for that day, or if I have not done any printing for an hour or two. The more I print the better it prints.
  • RichN Feb 15, 2008
    I have a similiar problem but only with blue color. I get 3 dark blue streaks on the right side about an inch in from the edge. O-max told me I need a drum.
  • Anonymous Feb 21, 2008
    I have shadows of lettering
  • Anonymous May 27, 2008
    smear in black
  • StupidNickna Dec 15, 2008
    I have an HP Color Laserjet 2605dn, and prints the entire background in red. We have replaced the magenta and it has not fixed the problem.
  • Publi-7 May 11, 2010
    I have the same problem, I even changed all the color, but everytime I print, I have smeared color all over the paper. I use the cleaning mode a couple of times, than print. But it comes back. Even when I print in Grayscale I have colors on my printed page. I even manually clean it up... Its works for about 2-3 prints, then here it goes again... :(
  • 589 Answers
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Posted on Feb 06, 2008
  • brian c
    brian c Feb 06, 2008
    Yes, that model used 4 separate drum / developing units - which also makes troubleshooting easier compared to the single drum / multiple developing unit models.
My printer HP 2600n not printing. This is local connection. How to fix?
Posted on May 24, 2008
I have a similar problem with the Black toner, Black is OK, grey come out smeared.
I was just wondering, is everybody using HP cartridges or Greener ones?
Posted on May 09, 2008
Text prints fine. However images are printed smeared. It looks like each image has a mirrored shadow. How can I fix this?
Fist set for default settings, calibrate color.. it will resolve the issue ..even its remin service involment must..
Sep 11, 2011 | HP Color LaserJet 2600n Printer
HP 2600 does not print onto photo paper
change the paper type in the printer properties and try.
Jan 09, 2010 | HP Color LaserJet 2600n Printer
Printer
Try this: '''Cleaning page'' in the menu, 1,2.3 times. The quality of print out getting better.
This solution is temporary, for a few pages in one day.
If the printer is used with high intensity, there is necessary to change the Fuser Unit for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v)
Oct 02, 2009 | HP Color LaserJet 2600n Printer
Yellow not installed
Are you using a factory new HP cartridge? If so, contact HP and request a warranty replacement of the toner cartridge.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
Printing color shadow
did you used a combat able cartridge ? if yes the ink is the problem if no the problem is firmware
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Smudges on right ride of paper
want the answer to this we have a hp 2600n laser printer and its leaving smug of color on the paper the big wide roller where the page gets printed is smear with all the colors. Is there a way to clean this and what to use so we can fix the problem.
connie petrik mu email address is connie.petrik@att.net please give me a answer to this problem.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Nov 30, 2007 | HP Color LaserJet 2600n Printer
HP Color Laser Jet 3550 Smearing Colors
Do you use original genuine cartridges or refilled ones. It sounds like you have had a leak and need to completely clean out your printer heads, rollers and perhaps do a deep claean as well. You can buy faulty cartridges and toners that have one leak, then the ink continually leaves traces as it prints. When you say callibrated, do you mean you ran print tests and setting tests. Running a print test can often help to diagnose ink issues an d narrow the results down a bit. After a thorough clean, you could try uninstalling and reinstalling unit.
Aug 11, 2007 | HP Color LaserJet 3500 Printer
HP Color LaserJet 2600n Printer Logo
1,448 people viewed this question
Seeker5211
Seeker5211
