Question about Nikon Coolpix 5700 Digital Camera
LCD display blank and shutter release won't work
After turning camera on, there are only two displays on LCD. One is battery level indicator. The other is (.1  (.2  (.3  (.R. Rotating the command dial cycles through these.  Also, the shutter release won't take a picture. If I push in the lock button on left side of camera, I can then take a picture.  This problem does not happen all the time. Thanks for your help
  • astwood Nov 04, 2008
    I have the same problem.
    My firmware is already version 1.1.
    Peter
    President:
  • 4,402 Answers
Update the current firmware
Posted on Feb 06, 2008
Why is image not displaying on LCD monitor?
Need more info. Does the menu display? Then LCD probably good. If the menu does not display, then LCD (or its driver circuitry) is probably bad. Not display after taking a photo? Or not display when you push the arrow button to turn on display. Check to make sure card is in camera. Set menu to factory default to make sure some setting in the custom functions isn't turning off the LCD. Also check the brightness level.
Jun 05, 2014 | Canon EOS 600D Rebel T3i Digital Camera
N 70 blank display solution plz
Not a lot to go on.
If the display shows up when you hold the shutter release down halfway, then the internal battery has drained. This battery-different from the EN-EL3 that serves as the main battery-runs the clock and keeps your settings while the main battery is removed. You may be able to recharge it by putting a fully-charged main battery into the camera and leaving it alone for three days. (This is in your manual.) After three days have passed, turn the camera on. Both displays should work like normal, and it should prompt you to set the clock.
Apr 17, 2011 | Nikon D70s Digital Camera
Canon Rebel XS has stopped recording images...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS .
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Rebel XS was working fine... yesterday, all of a sudden, the LCD screen went blank and it displays 'busy' when trying to take a picture. Recharging the battery and replacing the sd card didn't change...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
I hope that helps.
Nov 30, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Firmware install on Pentax ist DS. Had Ver2.0 & everything worked fine. Simply wanted to upgrade to V2.02 to used SDHC cards. User Power AC and install ran approx 90 secs and displayed showed half way...
You need to go to the support section of the Pentax website and engage in a live chat with a service tech using your computer or even a phone conversation to resolve your problem.
Oct 10, 2009 | Pentax *ist DS Digital Camera
The LCD display displays D: 3B13
problem is small as software update try www.olympus.com and big as CCD Failure
there is a strong chance of CCD Failure
pls do rate me
Dec 01, 2008 | Olympus EVOLT E-500 Digital Camera
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
LCD Display
I was cleaning my CCD and damaged the shutter. Same problem. Click to take a picture and the camera locks up and powers off. Turn the camera back on and the shutter releases and the camera resets and powers on. $281 service call later and Precision fixed it quickly. Replaced the shutter. They warranty their work for 6 months. Priced way too high, but nobody would touch it. As soon as I told other repair services how I messed it up, they turned me down. I had to much money invested in the camera to toss it in the closet.
Nov 24, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
Digital SLR "r06" (or other number) in LCD display
During shooting, or when the shutter-release button is pressed halfway, the number of images that can be stored in the memory buffer at current settings is shown on the exposure-count displays in the control panel and viewfinder. "r06" indicates that six images can fit in the camera's buffer, "r08" would indicate eight frames. Any other number could be displayed as well.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon Coolpix 5700 Digital Camera Logo
91 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
