Question about Ezonics OPUS 6000 Digital Camera
Opus 6000 Pictures are to bright, how do i get darker pictures
Press down button, btw, do you have the driver that you can send to me?
Posted on Oct 21, 2008
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
My HLP5063W tv comes on and works for 3 to 5 min then the pictures gets dark and the colors are distorted. The remote no longer operates the set and I can not turn it off using the front or side switch. ...
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours which is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen. Try Encompass .com ; shopjimmy.com
Jun 11, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Dark picture
If the pictures of a TV appear to be darker than they are used to be the first thing which should be checked are the brightness and contrast button. Check for them and increse either one or both of them to brighten your picture.
Hope this solution has been helpfulo?
Oct 25, 2010 | Mitsubishi Televison & Video
When I take indoor pictures, the images have become progressivley darker and I have to adjust the white balance to +2 and the flash to almost plus 2 just to get a picture where it used to take great...
Make sure your battery is fully charged. If the battery is not fully charged your flash may not fire at the brightness you need to take a well exposed photo. Also, check your ISO settings. Try taking photos at a higher ISO when the subject is in a dark area. Experiment with the ISO. Good Luck!
Nov 09, 2009 | Sony Alpha DSLR-A100 Digital Camera
Need memory card for OPUS 6000 digital camera
Hi there, and thanks for coming to FixYa.
The type of card you need for your camera is an SD Card and you can get that at your local electronics store. You can also get them online too.
Rob
Feb 27, 2009 | Ezonics OPUS 6000 Digital Camera
por favopr me podrian indicar que puedo hacer para que las camaras que tengo funcionen ya que se quedaron sin funcionar y que me en vien los drivers de intalacion para poder instalar
Oct 17, 2008 | Ezonics OPUS 6000 Digital Camera
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Pictures are underexposed
When you are photographing scenes with mostly light objects (for example, snow, water, and sand), the picture is usually underexposed (darker than it really is). The camera meter registers the brightness of the scene and tries to set the camera lens and aperture for an exposure based on average brightness levels (18% reflectance) causing it to underexpose, as in the following picture. When you are photographing scenes with mostly dark objects (for example, shade, shadow, and overcast skies), and very few light objects, the camera may overexpose the image, causing it to be too light. If you have a flash on your camera, you can compensate by adding "fill flash" for some extra light. If your camera has an exposure compensation adjustment, you can increase or decrease the exposure to correct for these exposure problems. Increase the number to make the image lighter, and decrease the number to make the image darker. You may want to try a series of shots with different exposure compensation adjustments to get a feel for how much difference these adjustments make.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Ezonics OPUS 6000 Digital Camera Logo
82 people viewed this question
Top Ezonics Cameras Experts
Marvin
Marvin
Are you an Ezonics Camera Expert? Answer questions, earn points and help others
