Question about Panasonic KX-T7730 Corded Phone
Panasonic Kx-T123230 extension to ring
How can choose for an extension to ring or not ring when outside call reaches through the Co line
  • 1 more comment
  • Anonymous Mar 19, 2014
    We have one extension that cannot pick up an incoming call when the reception unit is set to "Ring All". It can pick up incoming calls if the "Ring All" is not set
  • Anonymous Mar 21, 2014
    Under system internal self test every function works correctly
  • Anonymous Mar 25, 2014
    pickup ringing co
Hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
Posted on Feb 17, 2008
  • mydognameboo Feb 17, 2008
    correction,
    Outside (CO) Line Ringing Selection
    1) Press the PROGRAM button.
    2) Dial 3 ( from here should give you a choice, 1, 2 or 3)
    3) enter the outside (co) line number you want to ring
    4) press Store
    hope this help
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    On the Panasonic KX-T7633, how can you answer a call on extension 101 that is actually ringing/incoming on extension 103?
    A couple of ways, the easiest is to dial *41103 on the intercom. *40 may also work, but it picks up any ringing outside line.
    Carl
    Jul 20, 2011 | Panasonic KX-T7633 Corded Phone
    Panasonic KX TES824 Using KXTE console I am trying to forward extension 201(outside calls directed to 201) to an outside number. I have set in feature settings fwd to co and then put a 9 and number in...
    there are two conditions You have to keep:
    - call FWD to CO has to be allowed in reg 607 during system programming.
    - CO call has to come to extension in DIL1:1 mode.
    Mirro
    Dec 23, 2010 | Panasonic KX-TA824PK Phone
    Hi i have a panasonic KX-TES824 installed with 2 co lines and 4 extensions. I want the ringtones to be different for internal telephones (ie call between the extensions) and the CO Lines (when call comes...
    A Panasonic Analog PTS ring sound is not adjustable, however, the cadence is. An outside call rings with a single ring, an internal call is either voice announce or a double ring. The digital phones from Panasonic have either 8 or 30 different tones, but that's a different system.
    Carl
    Nov 21, 2010 | Panasonic KX-T7730 Corded Phone
    Hi would like to know how to set an extension not to ring when any of the co lines is ringing since i have a fax machine connected to this extension and it is programmed to answer automatically
    Ringing for each extension and line is done in Panasonic system programming commands 408-410 for Day/Night/Lunch. You turn off ringing for all lines to your fax extension and then just turn on one line for that phone.
    Be sure to turn off or delay the fax line ringing to all the other extensions at the same time.
    Carl
    Nov 03, 2010 | Panasonic KX-TA308 Phone
    Hi, I've just added and expansion card in my panasonic tes 824. but the problem is although the additional extensions are working. no additional CO lines are being detected. when i go to the CO line...
    No. At the very minimum, you need to go to program 400 (3.3 in the U.S. Maintenance Console) and turn on the lines. Access may have to be enabled from each extension for both outward and ringing programming might have to be added.
    Carl
    Oct 30, 2010 | Panasonic KX-TA824PK Phone
    I bught a kx-ta824, I just have one CO line and i want to put 4 extensions , but i couldn't. I can just recive 1 call and then the line sounds busy.
    With one CO line you can only make or receive one external call at a time. You can have extensions connected on intercom calls, but once your CO line is in use, anyone calling in will get a busy signal, as will anyone in the office trying to make an outside call. You'll need additional CO lines if you want to have several outside calls going on at once.
    Apr 10, 2009 | Panasonic KX-TA824PK Phone
    Panasonic KX-T7730 Corded Phone Logo
    490 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
