Question about Kenmore Elite HE4 Electric Dryer
Lint filter seems to be stuck
I am having difficulty removing the lint filter in the dryer. I have to jiggle it back & forth before it will finally come out. It seems to be haning up on something. How can I fix this?
  • Shinn Feb 28, 2008
    Thanks for the comment but I don't think this was the problem. My husband was actually able to remove the front cover of the dryer only to find that there was a belt of some sort in the way. I don't know how he fixed it but the lint filter now comes out very easily.
    Problem Solver:
  • 12 Answers
It sounds like you have a lot of lint buildup`the safest thing to do would be ,I know your not gonna like it . but take it to a professional and have it cleaned and serviced.lint buildup in dryers cause a lot of house fires.
Posted on Feb 28, 2008
  • ricky mack Feb 28, 2008
    thank you for listening.it is a good idea to have your dryer cleaned and checked at least every 2 years .depending on use.it will last you a lot longer.
Dryer is taking a longer time than normal to dry unless we switch it to timer. Replace sensors?
  • Remove and clean the lint filter each time it is used. The filter can be washed with warm soapy water to remove fabric softener residue from the screen.
  • Check the household fuses and circuit breakers. Most household dryers use two fuses or circuit breakers. It is possible for only one of them to trip and the dryer still tumble, but not heat.
  • The washer controls may have been improperly set. If the clothes are wetter than normal, coming from the washer, this could be the difficulty. If the gentle speed is selected for a normal load the washer will not spin adequately. High speed or extended spin removes more water from clothing decreasing drying time
A lint filter that is full of lint will restrict airflow and lengthen dry times. To keep your dryer working correctly, clean out the lint folder after each and every use. Check the lint filter for any buildup of fabric softener that will restrict airflow and wash with soapy water to clean. If the filter is damaged then replace it.
Nov 09, 2017 | Dryers
My kenmore elite dryer that i bought 2 years ago lint trap corner is catching my clothes and tearing them. we had it replaced and its doing it again. I am tired of messing with it. Please help.
don't know if you already had this fixed,usually this is caused by not having your dryer cleaned out,the lint builds up inside the duct that the lint filter slides down into and has to be removed and cleaned out.also in some of the kenmore dryer ducts there's a metal clip inside the duct that can come loose and hold the lint filter up.these are the two most likely causes for this to happen.
Sep 23, 2013 | Kenmore Elite HE4 Electric Dryer
How to clean debris below lint filter Frigidaire Gallery GLER341as1
Pull the exhuast vent off the back of the dryer, remove the lint screen and then turn it on for a few, should just blow out the back.
Jan 09, 2013 | Dryers
I took out the lint filter to clean and it will now NOT slide back into the slot. It just stops about 1/4 of the way up the screen. This is the first time this has happended in the 2 years that i have owen...
you need to clean out the dryer or have someone come in to do it.unplug the dryer,remove the lint filter and then you have to remove the duct that the filter slides into and clean that but you have to take the dryer apart to do this,next you have to vac out the cabinet where the motor is and clean out the vent line,if it's a long run i use a leaf blower to do this,remove the vent line from the back of the dryer,go outside and make sure the vent is clear then go back inside stick the leaf blower into the vent line and blow all the lint outside.you have lint stuck in the tracks that the lint filter slides into,get a skinny long screw driver and poke out the lint,if you have an electric dryer you should do this once every two years if it's gas once a year so you don't have a fire,next time send the model number and the name of the machine you need help with so i can help you better,if you don't know how to take apart the dryer send the model number and i can help you but there is lint stuck in the tracks that the filter slides down into and if that's like that then you need to clean out the dryer
Dec 23, 2010 | Dryers
My legacey washer is leaving lint on clothes
Of course you've probably already done this but if not, check the filter and clean it. Additionally, you might need to wash it to remove residue from dryer sheets and BE SURE TO DRY IT BEFORE PUTTING IT BACK IN THE DRYER. If the filter is clean and washed and you're still having lint, get a dryer brush and clean down in the area where the filter goes. Also go to the vent area outdoors and clean that with the dryer brush. That area can become clogged over time and prevent the dryer from effectively removing the lint. Furthermore, check the exhaust piping. If it is bent, gently move it a little to dislodge any lint that might have gotten stuck there over the years.
Nov 04, 2010 | Maytag Washing Machines
This morning my dryer stopped working when I put in a new load. It simply is not heating and the drum is not turning
YOU MAY HAVE A BREAKER PROBLEM. FLIP THE BREAKER BACK AND FORTH RAPIDLY. SECOND AND MOST COMMON THE WHITE THERMAL FUSE WITH BLUE WIRES TO IT HAS BROKE. LOCATED BEHIND THE LOWER FRONT PANEL. UNPLUG DRYER, REMOVE LINT FILTER, REMOVE LOWER PANEL, REMOVE THE LOWER DUCT ASSY. THIS IS THE PIECE THAT THE LINT FILTER GOES INTO. BEHIND THE DUCT IS THE WHITE THERMAL FUSE.
Apr 25, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer SHOWS ERROR 68 ON PANEL and shuts off?
Error 68 can mean that your start button is stuck; check to make sure the button is not stuck in the pressed position behind the controls cover.
Apr 25, 2010 | Frigidaire Electric Dryer
When I pulled the lint trap out there was much on
if it is a top lint filter take the lint filter out,turn dryer on,put your hand in it and you should feel a stong stuckion,if not remove the back panel and the 2 lint filter screws and check for clog-mike
Feb 22, 2010 | Whirlpool WED5100SQ Front-Load Electric...
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
77 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
