Question about Nokia N800 Tablet PC
Nokia N810 tablet wireless connection probler
I just got a N810 from Circut city online, it did the wireless connection when I charged and put in the battery, and worked very well, this morning tried to put mail notifier, it showed Server not found all the time...What's wrong? Please help.
Hi I had this problem and the security system of my main computer was preventing log on to computer and I had to disable it.
To allow access I think I need to put a computer ID and MAC code into the allow system.
Posted on Mar 03, 2008
Koool
Posted on Feb 29, 2008
I can not connect wirelessly
I have had this problem before and I had to go under WiFi settings and forget my WiFi. I let it scan again for service and reentered my WiFi network information. This worked for me most of the time. However, it could be your WiFi itself. Can you connect anything else to your WiFi?
May 15, 2015 | Chromo Inc Chromo AAAAAAAA Pink 4gb 7"...
The charging port is broken off, will the pad still charge wireless?
No. The wireless charger has to connect to the charging port via an add on cover on the device. Powermat Wireless Charging Pads from Duracell
Get a new tablet.
Mar 11, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My wireless Toshiba keyboard won't connect to my tablet
1. It connects via Bluetooth and not all devices are compatible with Tablet design. It does not connect via Wi-Fi.
2. Bluetooth devices require a PIN number to be put in the tablet for it to work.
See this web page for details.
Toshiba Wireless Keyboard Android Optimized
Mar 06, 2015 | Tablets & eReaders
Quezon city area code
ROBINSONS GALLERIA
Level 1 East Wing Robinsons Galleria,
Ortigas Center, Quezon City
Tel No. 636-0206 Fax. No. 636-5077 WALTERMART MUNOZ
2ND Floor, Waltermart Center,
North Edsa, Veterans Vil., Quezon City.
Tel No. 376-7439
Mar 31, 2014 | Coby Tablets & eReaders
I cant get wifi connection on my kindle hd
Step 1: Remove any old connections in the Tablet by Long Press Forget Connection
Step 2: Reboot your Wireless Router
Step 3: Attempt to connect again
Step 4: If this fails, log into the Wireless router and charge the authentication mode from whatever you have now to WPA Personal and enter a Passphrase you can remember
Step 5: Connect to your Wireless using the new Passphrase
Apr 07, 2013 | Amazon Kindle Fire HD
My nokia n810 tablet freezes when I turn it on!!
Isnt your battery drain ?
Have the same behaviour on mine ... I can reflash the system with supply on , but it wont stay long before reboot ..
Apr 11, 2010 | Nokia N810 Tablet PC
Touch screen (which is EVERYTING) on m NOKIA 810 no longer works. Screen is visable but NOTHING responds to touch. Any options besides using it as a paperweight?
have you tried the soft reset yet?
take out the battery and let stand in freezer (put in plastic bag to keep out moisture) for 10 mins.
hold down the switch key wich is right above the escape key on the left side of the screen. and hold down the power button till she turns on. once you get the usb symbol in the upper right turn it back off and it should run like normal.
Feb 04, 2010 | Nokia N810 Tablet PC
Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
Oct 18, 2008 | Nokia N800 Tablet PC
Nokia N800 Tablet PC Logo
347 people viewed this question
Top Nokia Tablets & eReaders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Nokia Tablet and eReader Expert? Answer questions, earn points and help others
