I'll write the same repost as another I just did, as it
sounds like your problem is the same or similar. Hope it helps solve
your problem as well even though it's a different camera and memory
card type.
Kristina,
Not knowing what model Olympus camera you have, or how old it is - your
new memory card "format" problem is one of 3 possibilities.
1st - If you have an older Olympus camera more
then 4-5 years old the newer M & H series type cards over 256mb
will probably not work in your older camera, as by the camera's
internal firmware chip design of the camera itself. Some cameras were
upgradeable some weren't as to the internal firmware chip as well as
available software drivers depending on which computer OS system you
were using ie: (WIN98SE, WIN2000, etc). Has to do with the memory card
read/write chip speed as well, and also has to do with the physical
storage size of the card itself. Some digital cameras were MAXED OUT at
512mb cards, some as low as 256mb. A 2gb card simple won't work in
that/your camera in that case.
If you read the camera's user manual it will possibly tell you this, or
else go online to www.olympusamerica.com and use this link:
View which cameras are compatible
Select camera model series and scroll down the model # and research the
max card size & type you can use (3 basic XD card speed types
available - regular XD - M type - H type).
If you are using the wrong type & size card you will need to return
that card (if you can) and get the right XD size & type for your
camera.
2nd - You should always FORMAT (same as ERASE ALL and FORMAT modes on
most Olympus cameras) the new card, or any XD card for that matter in
your camera itself. NOT THE HOME COMPUTER!!! The 2 format procedures
are not the same!!
If you are re-shooting (re-using) the same XD card over and over again
and then downloading the JPEG pix directly to the computer using a USB
interface cable there usually is no need to re-format the card again as
long as the XD card stays the camera and is not downloaded into a home
computer via a "card reader". If you do the latter "card reader" then I
would advise doing a card re-format in the camera again just to be
safe!!
And lastly - If your home computer recognizes the XD card via a good
"card reader" (do not FORMAT the XD card here btw, as you are just
checking the card out to see it is GOOD is all), but the camera will
not then that is a good sign your camera is OK, but it's just the wrong
type & size XD card.
Hope this helps solve your camera XD problem not knowing which model you have.
Best regards,
Frank
