Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
ZD7000 Lights, no fans, power switch not working.............
Wife was having problems with battery life. Said it worked for 1.5 hrs 2 days ago on a test and now nothing. I finally removed the battery. The switch to pop it out is jacked up. Used compress air to clean fans and kybrd. Now when battery installed I get all the blue lights, no hd activity, no screen, On/Off switch doesn't work. Just the all the blue lights. I get the same with AC power installed with or without the battery in except with the AC pwr I get the blue light in the front showing AC power connected...
any ideas??
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Posted on Feb 12, 2008
3 days ago, i went to work no problem,had to move it after 6-7 hrs of time, would not turn on 2 try's, started like normal on 3rd. 2 days ago i drove it locally a couple of times, no problems. today...
I ran into the problem and it was corrosion on the battery terminals. on the inside against the battery. also check the the terminals for good connection.
Stay warm
Dec 26, 2010 | GMC Sierra 1500 Cars & Trucks
Now it just will not start. It's was taking longer and longer to start. I tested the starter and replaced it. Now after a few (5-10 turns of the key) it turns over but wont engage and actually start. Even...
I would take the starter out and have it bench tested to verify if it has gone bad in the mean time.
Check the battery for bad connections and also for a full charge.
Check that the battery connections are clean and shiny and new looking when removed from the battery.
How old is the battery? 3 years is a typical life of most batteries sold and installed in cars these days. If unsure, then try a new one from the store which is fully charged to test, or connect a battery charger to your existing battery to see if it will take a charge.
Trickle charge your battery for up to 3 days to get a full charge on it.
Good luck on this repair.
Oct 29, 2010 | 1993 Subaru Legacy
Zero activity with ae-1 program camera
Is there film in it ? Remove it if there is,
If not you need to take it to a repair shop nothing you can do ... KC
Oct 19, 2008 | Canon EOS-AE-1 35mm SLR Camera
Just won't work
Hi cwhaley,
This issue can be resolved by performing power drain on the notebook.
Here are the steps:
1) Remove the AC adapter and battery from the notebook.
2) Press the power button and hold it for a minute.
3) Reconnect the AC adapter, battery and try starting the computer.
Sep 08, 2008 | HP Pavilion dv9000z Notebook
2001 Saturn SC2 Electrical issue
I had the same problem in a 1997 SC2.  Turns out that finicky/broken door lock/unlock switches were causing an intermittent short.
I removed the 20A fuses to these locks in the switch panel under the radio.  Problem fixed.
Sep 06, 2008 | Saturn SC2 Cars & Trucks
Schwinn s-400 scooter no motor activity.
I had same issue, bought a new controller. 40 bucks from the manufacturer. Works great.
Jul 20, 2008 | Transport Schwinn Rechargeable Portable ...
Ignition
See Procedure for REPLACEMENT.
1. Disconnect the negative (-) battery terminal. 2. Remove the crash pad side cover (A).4862483.gif 3. Remove the ignition switch (A) after loosening the screw and disconnecting the 6P connector.e5d4d9c.gif 4. Remove the steering column shaft (Refer to the ST group). 5. Remove the key warning switch and key illumination lamp (A) after loosening the screws and disconnecting the 6P connector.1ceff53.gif 6. If it is necessary to remove the key lock cylinder (A), Remove the key lock cylinder (A) after pushing lock pin (B) with key ON.5d997e5.gif 7. Installation is the reverse of removal procedure
Jun 14, 2008 | 2007 Hyundai Sonata Limited Sedan
Charging
look i have the same problem it taks so mush time to charge
it and you can onliy play with it like in a 1:00 hour only what it worng
Jan 11, 2008 | Archos 605 WiFi Digital Media Player
My IBM do not turn on.. IBM A21M..
check power ac adapter and batery if the batery is ok or charge do a test to the hard drive and memory ram loock on BIOS
Jan 03, 2008 | IBM ThinkPad A21m 2628 Notebook
505v battery
If you're talking about digitalkamera.de info, I believe it's incorrect. SONY japan's web page states 1300 shots and 1 hour life for the battery and it still uses the same battery from 505k, NP-FS11. I think it's possible they have reduced the internal circuitry power consumption (in 505v) to reduce battery drain, but the battery itself seems to be identical.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505V Digital Camera
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
209 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
