Question about Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)
Rinnai Propane tankless Water Heaters R85e-1
My new rinnai waterheaters (2) are controlled by a single control panel and are supposed to work together, so if there is high demand of hot water beyond the capacity of the 1st unit, the second unit will kick in and you should never run out of hot water.
For some reason, when we turn the hot water on, the flow occurs in intervals, that is, 10-15 seconds of flow, then it completely stops (nothing comes out) for about 5 seconds, then it flows again for 10-15 sec. and so on.
If I turn the heaters off at the control panel, the water flows uninterrupted.
These are Rinnai tankless waterheaters, which work with propane gas and are mounted to an exterior wall.
Any idea what may be causing the problem? Thanks.
The Model is R85e-1, (for some reason I could not enter that in the product line for this forum, so I had to pick a preselected option that does not match my product)
Is there anywhere I can order a part for a Rinnai external water heater...was told we have to pay a technician to come out and tell us what our problem is that we already know and they will order and install the part. We just want the lousy part to do ourselves.
Posted on Apr 04, 2011
If 2 rinnais are installed side by side they either work individually or seperatly depending on water demand. for the heaters to work correctly and in unison make sure the 2 units have a
'brain" or a circuit board installed. this will tell one or both to kick on when needed, if you do not have this installed then you will have the problem you described.
Posted on Jun 26, 2008
  • 1,420 Answers
Piping of these heaters in tandem is critical. Specified by Rinnai in their design manual, the cold water should be piped to both water heaters with a back-flow presenter installed before the first heater. The hot out piping should be "Tee-d" together and going to your hot water needs.
If piped as per the manual, try turning the water off to only one of the units. Turn on a hot water tap and see if the unit stays on without interruption. Then try the same on the second unit. You may find that one unit has a bad flow control, which is shutting off the flow of water.
You can get more technical help y contacting Rinnai direct at 1-800-621-9419 ext. 207.
Posted on Feb 07, 2008
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
Keep getting error code 10 for our rinnai rl75 tankless water heater how can we fix this?>
Go to the manual or go on line for the manual and look up the code and its meaning.
Aug 14, 2013 | Rinnai Tankless Water Heater Internal...
Controller not working
The rinnai is a computer that heats water. It is not ordinary water heater most people are familiar with, and repairs are not do-it-yourself, requiring a trained technician qualified in that brand who can diagnose both computer and water heater problems and plumbing problems.
Call rinnai for recommended local technician. Click on support tab. Note their webpage is very short on repair details, unlike companies that sell tank-type heaters... because tankless units are not do-it-yourself.
http://www.rinnai.us/tankless-water-heater
Problem might be simple blown glass fuse on circuit board or complete failure of computer and sensors.
Here is page written for Rheem tankless, that explains general complexity of tankless computers, and showing required maintenance, such as deliming each year:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
To save problems with tankless computers plus anticipated expense of maintenance and repairs, I recommend homeowner install tank-type gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Also install one-time-use whole house surge protector, and install grounding rods to prevent further damage... lightning frequently likes the same places over and again:
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 12, 2013 | Rinnai Water Heaters
Can you convert a natural gas rc80i n waterheater to propane
Contact manufacturer.
Generally the answer is probably no, especially if you have a family, children, dog and neighbors.
Propane burns Hotter and has more pressure than natural gas.
Burner must be more robust cast iron.
Orifices must be changed to accommodate different gas.
Different gas control valve needed.
In some cases there are dip switch changes for type of gas and altitude above sea level ... the higher the elevation, the hotter gas burns.
Here is expected result from changing NG to LP.
But your good luck might lead to less volatile result
http://waterheatertimer.org/images/Exploded-house3.jpg
Apr 21, 2013 | Rinnai RC80i Tankless Water Heater 8.0 GPM...
RINNAI R94LS CONVERT TO NATURAL FROM PROPANE
The electric water heaters have replaced the traditional of water heating. The advanced features and the latest technologies of water heater have made it so easy for everyone. Find the best electric water heater on the market today. Read electric water heater reviews and comments from experts. Almost each product is manually reviewed and tested.
Electric Water Heater List Reviews waterheaterlist com
Jan 28, 2013 | Rinnai R94LSi Tankless Water Heater...
Exterior mounted Rinnai tankless water heater not
check to see if you have a blocked line on the hot water side
Jan 08, 2010 | Rinnai Webstone The isolator EXP tankless...
Need to wire a zone control for a closed system with a circulator
thats because the rinnai does not have a set up for a circulating pump it would make the unit run all the time,, they are not designed to work that way,, you will have to just wait for the hot water to get to the faucet just like before,,don't let any one tell you there is a way once the water flows it turn on the tankless so it would never shut off, you could get on that goes on a timer on say the farthest fauset away from the unit and set the timer to come on like 2 min before you are ready to use the water in that bathroom in the morning or at night other then that there is nothing else you can do
Jan 28, 2009 | Rinnai Digital Remote Water Heater Control...
Question, is there any other equipment that uses propane? You indicate that the problem started after a delivery of propane after running out. If so, I suspect a blockage in either the gas train or the rinnai itself. If tou have the temperature control that regulates the water temperature, you can recall error codes to pinpoint the issue. They are optional equipment so if you can wire one in or ask your propane gas supplier if their service department has one, it will aide in the diagnosis.
Nov 22, 2007 | Heating & Cooling
Heating & Cooling Logo
584 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
