Question about ZoomCam 100 Digital Camera
Zoomcam100 usb error message, Driver open fail
  • WalidHsein Dec 01, 2008
    I have the same problem
    Driver open fail
  • Anonymous Feb 08, 2009
    I have the same problemDriver open fail, we need heeeellpppp!!!
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
Error: Webcam driver open fail. Problem with Satellite A305D
sounds like driver related problem, download this tool: Driver Update Software for XP Vista 7 8 update your drivers, and won't be any problem.
Jim
Jun 15, 2010 | Toshiba Satellite A305-S6845 Notebook
Error while printing message
Please try to powerdown your Printer and then your computer. Please restart both.
If you still are having the problem, then:
Try deleting and adding the printer again and see what happens from the printer setup utility if you are not able to print under another user and repair permission doesn't work.
Jan 09, 2008 | Brother HL-2040 Laser Printer
Error 211
When getting error 211, you will need to manually install the drivers for the adapter.
Exit from the error message, then remove the CD and restart your computer.
Plug linksys usb adapter, the computer will detect the adapter.
Right-click on My computer then click properties, go to Hardware > Device Manager.
Under Other Devices, you will see 802.11 g WLAN with an exclamation point. Right-click on it and select Update drivers.
Then insert the CD. (If the installation setup screen appears, just exit it.)
Then on the update driver screen, click browse and select your CD-ROM drive.
Then click finish.
If you are using Win 7, follow the steps from this link.
If you cannot open the link, just go to kb.linksys.com. In the search bar type 20873. Answer title: Error 211 - Installing Driver Manually for network adapters to work in Win7.
I hope this helps!
Apr 29, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
The Realtek EAPPkt Protocol Service failed to start
Try this..1.Try to uninstall the USB adapter and re install it again. To do this go to Add/Remove Programs under Control Panel and find the usb adapter your install in this case its Alfa Wireless USB Adapter and uninstall it and restart your computer after uninstallation. 2. Remove the USB adapter while restarting and insert it again until windows already loaded and all windows startup program have all been started.
3. System will look for the system driver of USB adapter and it will prompt you for the driver location in this window do not choose the recomended instead click browse and locate the driver cd and look for driver folder and select the applicable driver for your operating system such as WinXP if your using XP.
4. If there is no driver folder in cd, go to my computer, explore cd and run setup or install this will install the pending driver installation.
Nov 19, 2008 | Computers & Internet
Sound problem
The message that the installation failed means the drivers did NOT install properly. Uninstall the driver FIRST before trying the installation again. Failure to remove all the sound drivers will insure a failed installation.
Sep 02, 2017 | LaCie d2 Extreme 250GB External with...
Vivitar 3 in 1 Mini Digital Camera Error
Never buy vivitar - you are wasting your money!!
Jun 16, 2008 | Cameras
ZoomCam 100 Digital Camera Logo
Top Zoom Cameras Experts
Marvin
Marvin
Are you a Zoom Camera Expert? Answer questions, earn points and help others
