Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag top load won't drain
I have a 7 year old Maytag "Ensignia" Top load washer that doesn't drain all the water out in the final rinse about half the time. The timer goes to the end but the washer remains full of water. I can manually turn it around to 'spin' again and it drains fine. Sometimes it does it on the first load of the day and sometimes it won't have any trouble til the third or fourth load. A friend said she had this same problem once and it was a bad motor. I don't want to spend that kind of money if that's not the problem. Thanks
  • Anonymous Feb 15, 2008
    water does not drain from washer after final rinse
    Sniper:
  • 65 Answers
During spin is the tub making a slight roaring sound? if so the tub bearing is going bad causing the motor to work harder than normal causing it to heat up. this motor has a thermal protector which shuts it down , although the power to the timer remains therefore the timer still advances. this will require a new bearing and seal kit.
Posted on Feb 18, 2008
Washer will work in Rinse or Spin settings, but not any wash settings
If you are doing the normal procedures and the water elimination function is working, you have power to the circuit board and controls. The circuit board wash cycle section is independent and aligned with the timer circuit, thus the Wash Cycle Controller has failed. All of the functions or options are one the one board and a replacement board needs to be purchased and installed.
Feb 26, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
I have a Maytag Ensignia and the water will run but the tub will not fill.
You may have to just raise the drain hose up higher. It sounds as if the water is going out the drain hose as it tries to fill.Drain hose should be up as high as the top of the washer.Hope this helps.
May 28, 2011 | Maytag Ensignia MAV2757AWW Top Load Washer
My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Nov 20, 2009 | Maytag SAV5710 Top Load Washer
Maytag ensignia washer...cold water settings
You need to remove the cover and check the voltage to the cold water inlet valve. Do this with a volt meter while it is set to fill with cold water. It is most likely an AC voltage that is around 24 volts. If you have voltage then the valve is most likely bad.
Feb 16, 2018 | Maytag Ensignia 3.3 cu. ft. Top Load...
Rinse and drain
Just had this problem and fixed it by installing a new timer. Be sure to remember the order the wires were attached on the old timer.
Dec 16, 2007 | Maytag MAV7600 Top Load Washer
Water comes back in
Does after the second spin the tub fills with water again or stay with no water ?
Sep 04, 2007 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
177 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
