Question about Brother ML-300 Typewriter
Typewriter won't type letters
My typewriter just quit working while I was typing. I changed ribbons and it still didn't fix it. What is wrong and how do I fix it?
  • Anonymous Mar 24, 2014
    My typewriter only types half a character. I tried changing the ribbon but the problem persists.
    Champion:
  • 204 Answers
HI.. the hammer solenoid may be faulty..it should make a typing sound when you hit a key.( the printhammer moved and strikes the printwheel) or when you changed ribbons you might have unlatched the printwheel..there is a lever you press to relatch it until it "clicks"
If not that then make sure the ribbon is seated correctly, that it is between the printwheel and the black roller.Also visually inspect the ribbon so it is not caught in the printwheel.
Posted on Feb 06, 2008
Typewriter spaces the letters wrong and types the wrong letters
how to install and set the daisy wheel correctly onto the typewriter
May 22, 2013 | Brother GX-6750 Typewriter
I have an Olivetti Lettera 32. I put a brand new ribbon in it and when I type, the letters are coming up too light on the paper. How do I fix this? What needs to be done?
First thing is to be sure the ribbon is feeding, watch while you type. if not you may have a universal spool ribbon that isn't quite that universal. Wind the ribbon onto your old spools.
DickyO
Jun 06, 2011 | Olivetti Lettera 35 L Typewriter
I have a smith corona sd680 work processor typewriter. When I type the letter don't come out clear and I have to type over and over in order to read the letters. This is an old typewriter in the office...
This problem is usually caused by an old ribbon theey do dry out when left in tthe typewriter a long time, also if the paper is really hard or has a slick surface the ink from the ribbon will not stick to the paper.
Dec 14, 2010 | Smith Corona Office Equipment & Supplies
Typing only half letters
Possibly the lower edge of the ribbon has become folded over during fitting, it happens.
Apr 19, 2010 | Smith Corona Wordsmith 200 Typewriter
What is tyyping capacity of SMC 17657 ribbon cartridge
The 17657 ribbon is the side loading "pork chop" ribbon is a fabric ribbon and it shoulden't run out just get lighter until you change it you may just have a bad ribbon.
DickyO
Apr 13, 2010 | Smith Corona Office Equipment & Supplies
Typing half letters
If it was working befor you changed the ribbon check to be sure the ribbon's feet are engaged in the slots on the ribbon deck, that the blue latch is latched and there isn't a fold in the ribbon. If all of these are OK push down firmly on both ends of the platen.
DickyO
Feb 16, 2010 | Lexmark Wheelwriter 15 Series II...
MY IBM SELECTRIC II TYPES THE WRONG LETTERS. I CHANGED THE RIBBON, AND THE CORRECT TYPE. WHEN I PUT THE ELEMENT ON, IT STARTING TYPING THE WRONG LETTERS.
Not good. You probably turned the element while removing it and if you are lucky had it come off one of the pulleys, but more likely it came off the wheel under the element. Then you will need a tech.
DickyO
Feb 02, 2010 | IBM Wheelwriter 30 Typewriter
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Feb 27, 2009 | Brother Office Equipment & Supplies
Brother ML300 Typewriter
make sure the correction tape and ribbon are in properly between the metal fingers and the card holder. turn machine on and off. if it still doesn't work it needs professional help
Oct 22, 2008 | Brother ML-300 Typewriter
Diagram to change ribbon cartridge
The cartridge just snaps on, printing half letters may be caused by the ribbon being folded over on itself or not moving look at the ribbon toward a light you should see each letter clearly thru the ribbon
Sep 20, 2008 | Swintec 7040 Typewriter
Brother ML-300 Typewriter Logo
1,166 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
