Has i try to charger my phone it dose not charger. it will go to the boot screen and stay there fro a while but as soon as i pulged it out it turns off and i cant turn it back on
You'll have to let the iPhone charge sufficiently for it to proceed further from the boot screen. You may want to leave the iPhone charging for atleast half an hour before unplugging it.
Hello, friend! I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.They have professional unlock tools.
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
The dock connector is not too hard to replace or to reconnect. There is a stepby step guide too that explains a little bit at eachstep how todisassemble the iphone properly : iPhone dock connector repair. There are also third party iphone repair companies that do it for you.
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
