Question about JC Whitney 4-1/2'' Front/Rear Replacement Speaker Car Speaker
Front Speaker Replacement
I have a '97 Chevy Lumina and I am replacing the front speakers. Do I have to take the door skin off or do the grills pop off to get at them?
  • 82 Answers
You have to take off the door panel usually there is screws inside or around the handle then sometimes some around the edge of the door where the door striker meets look for caps thaty pop out and make sure all screws are out then the rest pops off take a flat head screw driver or something similar and put it between the metal part of door and panel right there close to where the door latch is (where the striker plate meets) then get your fingers up under and do small jerks where the window is slide up and run door handle thru opening
Posted on Feb 06, 2008
Have a kenwood stero ,putting it in a 97 chevy lumia,i need the color codes for the wireing horness.
1997 Chevrolet Lumina Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Yellow
Radio Ground Wire: Black/White
Radio Illumination Wire: Gray/Black
Radio Dimmer Wire: Brown/White
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Dec 30, 2011 | Car Audio & Video
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
How do you remove and replace the front dashboard speakers
There is a pop out grille. and under that is the screws holding in the speaker.
some GM vehicles have srew down grills as well.
Feb 26, 2010 | 1995 Chevrolet Lumina Apv
I have a 1997 chevy lumina and i'm putting in a new radio but the wires are not hooked up to the old one and i need to find out how to hook up the new one correctly. where can i get the wiring diagram for...
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Jan 09, 2010 | Car Audio & Video
I just had my left front passenger door completely replaced and now neither of my stereo speakers are working. Before the work was done the only speaker in the car working was on the drivers side but now...
Carefully pry the grill out and you can access the speaker and screws.If you have a 9Volt battery you can pop test the speaker with it just make you two short jumper wires and connect to the battery and touch on the speaker terminals if it pops its good if nothing voice coil is seperated. p.s. pry on the lower side of the grill cover.
Hope this gets you tunes!!!
Oct 24, 2009 | 1994 Honda Accord
How to replace front speakers in a daewoo leganza 02
You will need to either remove the door card or the speaker grill on the door card. To do this you will need a set of thin nose pliers for removing door clips, a flat head screw driver and a phillips screw driver for any cross head screws. Use the flat head screw driver to pop the grill off, if the grill is not removeable you will have to take the whole door card off. To do this you need to remove the electric windows panel as well as the door handle and lock panel, from their disconnect them from their harnesses. Then remove all clips and screws holding the panel in place. The door card should come free without too much effort, pulling upwards and away from the window. Unscrew the old speakers and disconnect the wires from them. Wire your new speaker to the same wire configuration as the old one. Screw it in. Place the door card back on and then plug the harnesses back in and place the door lock and window locking panels back in place. Do the same for the other door.
A professional installation will cost about $80 I think, I did my door speakers on my car and all I had to do was pop out the grill so it was easier than I expected.
Jul 17, 2009 | Car Audio & Video
How to replace front speakers in 1994 lumina apv
does the dash have speaker grills? if so they lift out, whether they are screwed in or not you have to check. if the dash and grills are one piece, you'll have to see if you can get to them from underneath. if not you'll have to pull the whole dash panel to change them.
Sep 22, 2008 | 1994 Chevrolet Lumina APV
Replacing front and rear speakers in a 1999 Mazda Protege
Whats the problem?
Back - Remove speaker grill, unscrew, climb in trunk, unplug - remove.
Front - Remove speaker grill, unscrew, pull out, unplug. If you have problems remove window winders and door skins
Dec 15, 2007 | Car Audio & Video
Car Audio & Video Logo
195 people viewed this question
Top JC Whitney Car Audio & Video Experts
Jaime Hernandez
xxxxxx xxx
Are you a JC Whitney Car Audio and Video Expert? Answer questions, earn points and help others
