Hi there, I am looking to fit a cd changer into the boot of my volkswagen beetle - 2000. I have been told by numerous people that there should be a connection in my boot prewired and if this is the case, what am I looking for and where do I look?
I have recently bought a Alphine Cd Changer 5952Z and was wondering if this was compatible without having to get a new head unit?
Your best bet is to find a VW cd changer as it will just plug into the car. To locate this there is a panel that opens up which covers the first aid kit there will be a spot for a cd changer to fit in. in the unlikely event that you need to connect the cable on the back of the radio there are slots on each side which you simple press in and the radio can be pulled out to check the connections. Warning if you disconnect the battery or unplug the radio it will require a code to unlock it after it has been plugged back in. A dealer can provide this code if you do not have it already in the radio operation booklet
SOURCE: wiring schedule for 2002 new beetle volkswagen radio
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
