Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Wd64 thermostates keep going
States stop working after replacing them, how do i get to any blockages that might be causing it to over heat, or could it be something simpler? jason
    Scholar:
  • 90 Answers
Need more details on this as I am not familiar with model numbers...washer or dryer....describe in some detail what is happening.
Posted on Feb 10, 2008
Three of the four stove stop heating elements thermostate doesnt work. It is either on fully or have to turn off to manage heat. remedy ?
Hi, You will have to replace the switch with a new one. That is all that is needed . Good luck.
Jan 12, 2016 | Dryers
Problem with Hotpoint WD64 Washer Dryer
this possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Oct 31, 2008 | Hotpoint Aquarius WD640 Front Load...
No heat when stopped for traffic
1-your thermostate is stuck open half way. thermostate is a simple device that made of enlarging metals when heat is applied. it suposed to be in close position to allow engine heat up, when specified temp reached it opens and let it flow and radiator tries to keep coolant cool.when it is broken it stucks or it acts slow or it wont acts at all. in your situation it is stuck open half way. it allows enough water to be heated but flow is limited to heat cabin heater.
2-if there are cabin heater selenoid/selenoids for two different temperature for cabin left and right, on some instance those selenoid valves to adjust cabin heater stuck open or closed like thermostate acts on first case. so heat is not enough to heat up cabin heater.
Nov 18, 2011 | 2005 Chrysler Sebring Conv
I have a Kenmore series 90 dryer about 15 years old which stopped heating last week. I found several videos on you tube which detailed the steps to troubleshoot and repair. The steps were to check...
Blown high limit fusees can be caused by.
  1. Not enough airflow caused by blockage in the exhaust vent pipe.(most common) Check for strong airflow coming out of the back of machine, then check for good airflow at exterior vent. Clean vent if airflow is restricted.
  2. Bad drum seal
  3. Dirty lint screen
  4. Broken blower wheel
  5. Blockage inside the machine.
Jul 19, 2011 | Kenmore Dryers
MY CAR IS OVERHEATING BUT NO SMOKE...IT SAYS THAT THE COOLANT IS HOT STOP ENGINE IDLE ENGINE..WHAT DO I DO? WHAT COULD BE WRONG? PLEASE HELP
a bad the thermostate could be not opening at all thus overheating the engine ,it should be replace with a new thermostate.click on the blue hand if I was helpful thanks.
Mar 02, 2010 | 1995 Cadillac Eldorado
I have a 2000 Tracker and the heat just stopped working - What could be the cause?
There are thermostates the will stick in the open postion1 this will cause you not to get heat if that is the issue. Air in the cooling system will cause this too. Or low coolant check your coolant level!
Jan 15, 2010 | 2000 Chevrolet Tracker
Van keep over heating after replacing water pump,thermostate .
checked for loss of water? and check oil for tan color
indicating a water /oil mix .
any white smoke at the tailpipe?
and last maybe thermostat sensor is connected with no shorts.
Aug 24, 2009 | 2002 Dodge Grand Caravan
Hi, my vulcan 750 (1995), over heating, how to solve it. thanks; from sharil
dear sharil you havent gave to much info about your heating problem. the most common cause for this prblem would a stuck thermostate,or a bad waterpump. but iwould replace thermostate first. not a big job but just a small warning after replacing thermostate and replacing antifreeze be sure to bleed air from system. a little bleed screw is located near the thermostate housing for this purpose
Mar 26, 2009 | 2004 kawasaki VN 750 Vulcan
Blowing high limit fuses
Check the blower wheel attached to your motor.
It may be free-wheeling causing too high a temp thet is blowing the fuses.
Feb 22, 2009 | Amana ALE230RAW Electric Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
76 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
