Question about HP Photosmart 2710 All-In-One InkJet Printer
Plastic guide strip behind cartridge assembly broken
The Plastic guide strip which runs behind the cartridge assembly has broken. I need to know if I can buy a new one, but don't know what it is called and if it can be bought from HP
  • jim496 Feb 07, 2008
    Thanks for that
It can be bought from a service center, it's called "Encoder" or "Position Encoder".
To make sure it's the encoder, if you turn the printer ON it will say that the carriage is blocked or will flash the lights showing that problem.
Posted on Feb 07, 2008
I have a lexmark x4650 printer and my son pulled a plastic strip from some where. Now my printer tells me that the cartrige is jam. When I opened it there was a small spring that I have no idea where it...
The "plastic strip" could be the encoder strip (responsible for the movement of the cartridge carrier on the assembly). This article will give you an idea on how to re-seat the encoder strip on your printer: Printer Cartridge Stalls or Is Blocked.
If you still need assistance, please contact Lexmark Technical Support Center.
Aug 16, 2011 | Lexmark X2350 All-In-One InkJet Printer
My printer is canon mp198 while i trying to fix my ink cartridge, accidentally i pulled out a plastic strip that was located behind the ink placement cartridge. and now the ink cartridge moves very fast...
You have most probably snapped the end of the encoder strip (the pastic strip) as it is spring tensioned. Look at both ends and there is a square cut into it. one of then will be broken and only a new strip will fix it. You should be able to buy a new one from any canon supplier. i cant give you a part number as not a uk model. Oh by the way there is a right and wrong way around so look at the old one before removing it.
Jul 08, 2011 | Office Equipment & Supplies
My canon MP258 show error code on screen E03, what should i do. help someone can help me. really appreciate it.
That is due to the clear plastic strips inside the printer, the one that run behind the cartridge holder, being dirty or damaged. This plastic strip with black marking on it, is used to tell the printer where the cartridges actually are. Unfortunately it could also be the sensor that reads this strip being damaged. Inspect the strip with a bright torch to see if any ink or dirt is on this strip, use a bright torch when doing so, it makes it much easier. Also check behind the cartridge holder for any torn bits of paper that could be jammed in it. Make sure the printer is unplugged from the power during this!!
I hope this helps
Regards GM
Apr 08, 2011 | Office Equipment & Supplies
A plastic strip that runs behind the ink cartridges has fallen off. its a quarter inch wide and about 12 inches long. each end has a slot cut at a 45 degree angle and an eigth of an inch from the end. I...
That is the ink guide. If the plastic strip connector (the slot cut on both sides) is not damaged/broken, the other metal tab may have fallen making the plastic strip to fall. It is usually soldered on the metal frame of your printer, find the missing tab and solder it back in. You should find a trace of the tab's original location.
Apr 17, 2010 | HP PSC 750 All-In-One InkJet Printer
Where is the carrriage located on my hp 7310 officejet printer?
The carriage is the unit that holds your ink cartridges, usually parked on the right side. When you have carriage stall or carriage jam you usually need to clean the clear plastic strip that runs across behind the carriage assembly, and make sure there are no scraps stopping the travel of the carriage.
Dec 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I have a hp psc 1517 and there is a thin strip of plastic behind the ink cartridges, my daughter pulled it out can it be put back in and if so how
Sounds like you are refering to the encoder strip. It is a thin clear piece of plastic with little black lines all the way accross the length of it. The printer has a sensor on it that reads these lines so that the carriage assembly knows where it is inside the machine. It is usually spring loaded on one end of it. Both ends of the encoder strip have a notch on it. One side of the encoder strip hooks onto a fixed mount through one of the notches, the other side hooks onto a spring loaded mount. If your daughter didn't pull it all the way out of the machine it is a bit easier to reinstall because all you need is something skiny and long like a pair of needle nose pliers to reattatch it to both of the mounts. If it is all the way out the strip needs to be threaded back through the sensor on the back of the carriage assembly(the thing you intall the ink cartridges into). Hope that helps a bit. It is a simple problem for a tech to fix but could be more difficult if you are trying to do this without removing any of the covers.
Oct 03, 2009 | HP PSC 1315 All-In-One InkJet Printer
Erroe code 5100 pixma ip1800
5100 means either the carriage can't move properly from right to left, or the encoder strip behind the carriage assembly has grease or ink on it and needs to be wiped with a Q-tip. Sometimes the cleaning assembly on the right gets stuck in the up position and stops the carriage.
Jul 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
Child damaged HP6110 - Help
It stretches from left to right behind the cartrige assembly and the assembly slides on it. It's a sensor strip for positioning the cart. asm. I'm not sure how it attaches, but you'd have to take the unit apart to do it.
Good luck...
Geno
Mar 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Epson stylus photo r300 printer
those parts are not user-replaceable
call the vendor - check your warranty status
check this link just in case : http://www.epson.com/loyalty
Dec 27, 2007 | Epson Stylus Photo R300 InkJet Printer
HP Photosmart 2710 All-In-One InkJet Printer Logo
249 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
