Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Start up problems
I have plugged in all usb ports and the free agent keeps beeping
  • CannonBooks Feb 15, 2008
    My freeagent drive has been working for a few weeks. I recently installed an HP all-in-one printer (don't know if this is causing the problem) and now the drive will boot up (autoplay detects it, light turns on, hear disk running, and weird beeping) then shut off thirty seconds later. It will do this over and over again all day. What the heck is going on?
  • kat4 Feb 24, 2008
    My freeagent works fine when connected directly to my laptop but when I use a (powered) usb hub it beeps continuously and isn't recognised. My computer only has 2 usb ports so I can't use a mouse at the same time as the drive.
    It seems lots of people are reporting such problems and noone has gotten any response. Nothing in the documentation about what the beeps mean.
    Problem Solver:
  • 15 Answers
I have little knowledge about the FreeAgent, but the beeps to me suggest power problems...
kat4 - Sound sliek your freeagent is working fine, and that it's the hub that's your problem. If it's a lower end brand you might consider getting a better one.
copper-top - Have you tried pluggin in the drive directly into a USB port built into your computer, and not through a usb hub, or other device?
CannonBooks - I have the same question for you as copper-top, but for you I suggest trying this drive without the printer plugged in, and see if it once again works. If it does, you might consider getting a good-quality powered USB hub and using that, or try pluggin the two devices into seperate hubs (if you are using hubs currently), or one/both directly into your computer.
Posted on Mar 17, 2008
FreeAgent Pro USB broken -- need data from Momentus drive
Momentus is a SATA drive, so you can put it in any PC that has SATA bus to access the drive.
If you can borrow a SATA to USB dock, you can put it in the dock and plug the dock to USB port on a computer to get your data out the drive.
One example for the USB dock is EZ-dock and you can search on Internet for the picture.
Apr 11, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
MY Seagate Free Agent Pro 750GB External Hard drive is no longer registering on my computer. It's only about 1/3 full and I need to recover the data. The software on my computer does not detect a free...
Sounds like the enclosure has a problem. If this is one of those free agent go flex drives with the removable USB to Sata interface you might try getting another drive like it and borrow the interface from that drive when you need to use this one. That's something I have to do now because one of my interfaces died also.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | Seagate ST307504FPA1E3-RK FreeAgent Pro...
My seagate free agent desk 500 gb makes beeping sound when I plug in the power cord. it does make sound, feels like disk moving/ vibration when plugged in but beeps and does not register or pick up signal...
This sounds most likely like there is media/platter damage occurring if you feel the motor turning. Nothing you can fix on your own, you need a professional with a clean room to examine the issue.
Jan 09, 2018 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
HI! I just bought a free agent 1TB to USB 2.0.
I'm not familiar with Carbonite but can't see why you couldn't use it to backup your new drive provided your PC just sees out as an ordinary (if external) drive. As for USB compatibility, the USB specification is backward compatable so your drive should work fine, if slower, when connected to a USB 1.0 port.
Hope that helps.
Aug 13, 2017 | Seagate Free Agent Go Small 12 GB USB...
Cannot read
It sounds almost like 2 things are happening,
1. The drive itself it going out or the board inside that is connected to the drive is bad.
2. or the drive is not getting enough power through the USB ports (or too much maybe?)
I have only encountered the beeping issue on my free agent 160GB when it was not getting enough power to spin up the platters.
If you still have warranty on it. I would HIGHLY recommend you call western digital about it.
Mar 20, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My light is on and a buzz sound is heardwhich stops after a minute and no data is displayed
You do not say whether the HDD ever worked.
If it did, and stopped, chances are that the internal HD is damaged, or the motor performances degraded and it now requiring a higher current than the USB port can deliver.
Try plugging it on a different USB port or, better yet, into an externally powered USB hub. There are also special cables which plug two USB ports into one and deliver double current to the appliance.
As a last resort, it might be possible to recover it by extracting it from its enclosure and connecting to a desktop PC via a 3.5-to-2.5 inch HD adapter.
In all cases, unless it never worked on that PC (which means that the problem might be in that PC's USB port), I'd strongly suggest to back up all data on another disk.
Oct 26, 2009 | Seagate Free Agent Go Small 12 GB USB...
Seagate free agent 1.5 terabyte will not stay connected to my computer When I connect my free agent to my computer (Asus laptop with Vista Home premium) all the folders show up and I can access files for...
Check the HDD on a different USB port. It there is still problem, try that with a different computer. If it still shows this issue, try changing the USB cable. If the issue persist, its your HDD.
Jun 06, 2017 | Seagate Free Agent Go Small 12 GB USB...
Maxtor One Touch 4 is beeping when I connect it by usb
Does the HDD spinup?
My slightly educated guess... the Ext 2.5in HDD requires more power than it is getting from the single port.
1. Try another port
2. Try it on another computer (all USB ports do not provide 250ma to a load)You may be sharing this avail voltage with all plugged in devices and will have to pull 1-2 others to get the HDD online. Since STARTUP current is high, the HDD pulls all it can from the ports (logical) then settles down and uses 1/3 to keep spinning. After the HDD is up and online, try plugging the other USB devices back in, 1 at a time. If it stalls the HDD - you know the why
3. Take it back and find something a bit less power-hungry (Like Hitichi or Toshiba)
Jan 16, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
I plug my seagate into the computer. it turns on but then nothing
Plug one usb into your computer and the other end into the drive.
If the light comes on, all is good. The computer should install the device for you automatically. To access the drive, go to My Computer and double click on the Removable Drive. Now you can transfer files.
Hope this helps
Chris (ziraffa)
Dec 28, 2008 | Seagate Free Agent Go Small 12 GB USB...
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
265 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
