Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflowed!!!
Let me paddle on over to the PC to ask this question. Our 80 series (7-8 years old) has twice in the past year not stopped filling the washer and what results is a flood!!! the first time it happened we caught it right away and chalked it up to a large load. However, it happened again yesterday. We had a small load of clothes on "medium." We have tested it since and now no problem but something's up. I would appreciate your support. Thank you.
The most common cause for this is the water mixing valve plunger sticking. the fix is to replace the mixing valve. Not so common is a defective water level pressure switch. Same fix, replace the switch. Really rare is a small leak in the tube from the tub to the pressure switch.
Posted on Feb 06, 2008
Kenmore Series 80 Heavy Duty Gas Dryer turns on but drum won't move - is this likely a belt problem? Dryer is about 12-13 years old. Model 75651
Good day,
Reach in, and see if you can move the drum. It will be a little stiff, but should turn.
If so, yes, it is probably a belt.
Look below. (Yes it is made by Whirlpool).
If hyperlink won't work, then copy and paste it in the address bar of your browser.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 10, 2009 | Kenmore Dryers
80 series Kenmore just over 1 year old. Buzzer contiues to buzz, have to open door to stop instead of normal 5 second operation. Timer continues to run even after passing off.
Hi, Unfortunately this sound's like a faulty timer. Most of those 80 series Kenmore's have the buzzer/end cycle signal built onto the timer, that added to the issue of the timer continuing to advance past the "off" position indicator, I'd suspect a timer. You should check with Searspartsdirect or partsdepot etc. as well as any other local and on-line part's supplier on available new or rebuilt timer's. Often rebuilt timer's are just as good for half the price of a new one. Hope that help's. If so please give a rating on the info I provided to you here at fixya. Thank's for using fixya and come back if you need further assistance. Good luck macmarkus:)
Dec 08, 2009 | Kenmore Dryers
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Kenmore washer 80 series
you need to check the lid switch, does it click. you can unplug and then remove the 2 screws to see it, if it looks like it is coming apart then the lid switch is bad. you can buy one for about $40 or so dollars. i am assuming it doesn't spin either.
Dec 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Kenmore 80 series washer
Your transmission is not engaging thats why the speed changes your making will sometimes get it to work.Honestly any machine after the 10 year age mark is not worth the cost of replacing the transmission.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing machine
it has a little semi clear or black 1/4 of inch, long hose behind the control panel , who its attached one side to the level pressure switch and the other side to the tub. culd be only this three options clogged ,bented or unnatached this hose to one of the sides tub or switch easy fix
Jun 10, 2007 | Kenmore 20172 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
205 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
