Question about Watches
Need to set time on WalMart TGHK watch.
Hi - we bought a WalMart watch with TGHK engraved on the back. It's pink, water resistant, has stop watch features and a large face. Trouble is we lost the instruction sheet - and we don't know how to change the time to correct time. Can anyone help?
  • Anonymous Mar 17, 2014
    TGHK AW-91-731 how to set time
Use the Mode button to get to the time display. The seconds should be flashing. Then press the Reset button once and the Hours should flash. Use the ST/SP button to increment through the hours. When the hour is correct, press the Reset button again the get to the flashing minutes display. Go through these steps until all items are set the way you want them.
The alarm is done similarly by pressing the Mode button until the AL displayes and if in small font the ALM and/or CHI display next to the AL, you can turn them off by pressing the reset button until both are off. If you do want the Alarm and time set then leave ALM set but set the time using the reset button to get the hours flashing or minutes flashing and use the ST/SP to increment to hour/min you want. Finish the sequence by pressing the Mode button once. If the ALM or CHI are set, then in the Time display you will see the ALM and/or CHI indication next the day of the week.
Posted on Nov 04, 2013
  • Admin RS
    Admin RS Jan 07, 2015
    Terrific directions - really helped. Thank you
    Scholar:
  • 98 Answers
If its digital that makes it more difficult to give setting directions online. Need to know the exact model #. I would do a google search to try and find your watch and you might find a manual online. OR you could seek out a local watch repair business and they should be able to set it with no problems. Most Sears have a watch repair kiosk in their stores! I woudlnt take it back to Walmart because they are just sales people! They have limited watch knowledge!
Posted on Jan 09, 2010
    New Friend:
When ever i press the reset butten when i am finished setting the time it goes back and forth to the hours to the mins and it keeps on doing that
Posted on Oct 25, 2015
SOURCE:
Tip
TGHK watch instructions
This is not for Tag Heuer, it's for TGHK watches.Here's the procedure: Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode). Press the RESET switch to advance to the function you want to change (e.g. hours). Press the START switch to increment the hour to the correct time. Press the RESET switch to advance to minutes and, again, increment the setting using the START switch. (Hold the switch down to advance the numbers rapidly.) When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display. To set the ALARM: Press the MODE switch to display the alarm function. Press RESET once to see the hours blinking. Press the START/STOP switch to advance to the desired hour. Press RESET to advance to the minutes and set the minutes using the START/STOP switch. Press the RE#SET switch. The time will stop blinking. Set the alarm sound for either ALARM or CHIME using the START/STOP switch. Press MODE to return to the time display. To turn the ALARM off: Press the MODE switch to advance to the alarm mode. Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off. Press MODE to return to the time display.
on Mar 18, 2010 | Watches
R ingraved on back
A personalized engraving on the back of a watch case means nothing as far as its authenticity is concerned. Think about it an engraving can be done at any time after the manufacture of the watch is completed so how could an engraving or lack there of tell you anything about authentic? I bought an older Day-Date President a month ago and it had the persons name, birthday, and SOCIAL SECURITY NUMBER engraved on the back. What is interesting about this particular engraving is that it is a fairly bad engraving. Which means that an unskilled person did the engraving, but that is all it means. The particular watch I am reffering to is very real indeed. All that aside I'm going to say that your watch is fake. That is a 20K watch and the fact that you don't know how the engraving got on there indicates that its more than likely not real. That's also one of the most commonly counterfeited Rolex's. If you wanna know for sure take it into a pawn shop and tell them you want to sell it. Just don't argue with the people when they tell you its fake.
Dec 16, 2013 | Rolex Daytona 116520 Wrist Watch
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
There's no way an engraved winner rolex 24 at daytona 1992 could be real? why would counterfieters bother putting such an obvious indentifier of a fake on their fakes?
There has been a Daytona with similar to this on the back that was presented in 1992 ..but....... If your watch has AD DAYTONA on the back it is certainly a fake and sadly worthless.
Jan 21, 2013 | Rolex Daytona 116520 Wrist Watch
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    Set time on tghk watch
    As there are no possible watch manuals for unknown brands, all I can say is:Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Go through all and you will find the right one, as all watches stand on globally accepted basics. It may take some time, but at the very end you will get what you want.Rate me, please
    Mar 15, 2010 | Watches
    TGHK hourly chime, and military time
    Go to alarm screen and press light and st/sp at the same time.
    Sep 23, 2009 | Watches
    Is this a genuine Cartier serial number
    is the watch real is it says cartier r1628 water resistant swiss made 2301 cc708177 ???
    Apr 13, 2008 | Watches
    Watches Logo
    9,135 people viewed this question
    Top Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
