Question about Dell Dimension 3100 PC Desktop
Drive 0 not found;serial ATA,SATA-0
I shut down my computer, remove my sata hard disk and connect it to another computer to transfer data but the computer does not detect it.I return it back to my first computer but when i switch on, i have this message--drive 0 not found;serial ATA,SATA-0
I have check the cabling as well as enable the sata 0 in the bios but it dont detect the hard disk!!
Can you help me please?
  • Anonymous Mar 19, 2014
    4 drives plugged in only 2 detected
  • 50 Answers
Are you SURE you connected up the power connector in addition to the SATA connector? If so, you may have hozed your drive.
Posted on Feb 06, 2008
I've a Fujitsu MHV2080At like external disk and from some days PC don't recognize Hard disk and this is "dead" , the led's are ok when i connect USB but the head of hard disk don0t...
  1. Serial ATA:  If you have a 3.0 Gbit/sec SATA drive that is not being detected by your 1.5Gb/sec SATA controller, or it causes your system to lock up when connected to a 1.5 Gbit/sec SATA controller, you may need to jumper your 3.0 Gbit/sec SATA drive to the slower speed of 1.5 Gbit/sec for the system to recognize it properly. For further information on changing the jumper setting to slow down your SATA drive's transfer rate, please see Document ID: 193775
    -48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA:  It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used. Please consult Document ID: 196299 for further instructions.
  2. Faulty Hard Drive
    If you have completed the above checks and procedures and the drive is still not properly detected, please attempt to use Seatools for DOS (see the tutorial here) to test the drive.  If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
Sep 19, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
How to install sata harddisk
With Serial ATA technology quickly replaince IDE/ATA as the new standard in hard disks, more and more computer users will need to know how to install SATA hard drives. The process of installing a SATA hard drive is similar to installing an IDE hard drive, except a bit simpler. Follow the directions in this article to learn how to install a new SATA hard drive.
1.Detemine whether or not your hard drive supports SATA. SATA technology was not introduced into the market until after 2002, so any consumer PC before that will not support a SATA hard drive. To find out whether or not a SATA hard drive can be installed into your motherboard, you can review the manual that came with your computer, or you can contact your computer's manufacturer. If you have already purchased a SATA hard drive, but have your motherboard does not support SATA technology, you will not be able to use your new hard disk.
2.Power down your computer and remove any peripherals or connections. Ground yourself either by wearing an anti-static wrist strap, or by touching a piece of unpainted metal. Remove your computer's case.
3.Locate your hard drive bay. Your hard drive bay should be located beneath your CD/DVD drive.
4.Locate the SATA data cables on your motherboard. Review the image to the left to get an idea of how your SATA slots may look (not all motherboards look the same). The small, red connections on the bottom-left of the motherboard are your SATA connections.
5.Take your SATA data cables (the red, smaller cable pictured left) and plug the one end into the motherboard. Insert the data cable into the lowest numbered slot (i.e. 0, 1).
6.Next, you will want to locate your computer's power cable. Some computers will already have a SATA-compatible power cable available, but others may not. If your computer does not have a SATA-compatible power cable, you will need to buy an adapter. As in the picture above, it will have one white end and one black end. Plug the white end of the adapter into the white end of the power cable in your computer. It should look identical to the one in the picture.
7.Connect the data and power cables to the back of your hard drive. The larger cable goes in the larger slot, whereas the smaller cable goes in the smaller slot. If they do not fit at first, simply turn them around and try again.
8.Slide your hard drive into the drive bay. You will want to make sure that the part of your hard drive with the connections on the back is facing outwards. Then, taking a screwdriver, line up the holes in the bay with the holes in your hard drive and screw the SATA hard disk into place.
9.Power on the computer. If you have installed two SATA drives, unlike with IDE, you should not have to designate them as master or slave (both will be independent drives). If your computer is not reading your new hard drive, power down the computer and check all connections, making sure they are secure.
Sep 08, 2011 | Computers & Internet
I asked this a few days ago; , I have a Samsung SpinPoint P80 SP1604N 160 GB Hard Drive in a HP compaq presario SR 1617CL I want to replace it with a larger HD, 500GB or 1TB. Can I replace it with a...
Yes, either of these drives will work. The cache is not all that important it is just where data is stored temporarily in case you have to access it again soon after a file is written to the hard drive. The best thing you could do in this case is see if your motherboard has a sata connection which I would assume it does and buy a sata hard drive. It will be much faster than either of those drives, just make sure you also get a sata power adapter if your power supply doesn't already have one and a sata cable.
Mar 11, 2011 | HP Compaq Presario SR1620NX...
Drive 0 not found Serial ATA, Sata 0
Check the jumper settings on the primary hard disk drive and set to master. Also check that the cables and connectors are firmly in place.if problem persist, drive may be bad
Sep 17, 2009 | Computers & Internet
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
My Computer did not access Western Digital Hard Disk, Model No. WD 1600 AABB Caviar SATA.
Good morning! Please make sure that the drive’s power and SATA cables are properly connected. If the Serial ATA host adapter card is installed in a 64-bit PCI slot on the system motherboard, move the card to a 32-bit slot.
Verify that only one power cable (either SATA or legacy) is connected to the drive. Check to see that the power connector and SATA interface cable are securely attached and that the
SATA host adapter card is properly seated in the PCI slot.
The Serial ATA interface connects each drive in a point-to-point configuration with the built-in SATA port on the motherboard or with the SATA host adapter card; therefore eliminating the master/slave relationship as required with EIDE. Each drive utilizes its own
cable for data transfer rates. Jumper settings for Western Digital Serial ATA hard drives are mainly used for enterprise storage environments.
Most third party controller cards and RAID adapters are recognized as a SCSI device under Device Manager. This is normal and will not affect your drive or system performance.
To verify if the Serial ATA drive is recognized by the system, Right-click on the My Computer icon, select Properties, left-click on the Hardware tab, and click on Device Manager in the window. Double-click on Disk Drives. Your new Western Digital Serial ATA drive should be listed as a "SCSI Disk Device" or "Serial ATA Disk Device." If not, make sure that all cables are securely attached and that your system BIOS has been properly configured. regards
May 12, 2009 | Computers & Internet
It wont start.. what is sata?
You have to make sure first, what is your HDD type? is it IDE or SATA (Serial ATA).
Check it out: http://www.wisegeek.com/what-is-sata-or-serial-ata.htm
You should plug the data cable, to your hard disk. Remember, there's no way to plug your SATA cable to IDE HardDisk because the connector are not the same (I don't know if there's a converter between it).
So, make sure it first. If it IDE, find IDE data Cable, and make sure it plugged to your MainBoard and Hard Disk. Do the same procedure if it is SATA Hard Disk, only this time you should connect the SATA cable from your mainboard to your SATA Hard Disk.
Mar 11, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard drive
According to http://reviews.zdnet.co.uk/hardware/desktops/0,1000000973,10004197,00.htm this tower has Serial ATA, or SATA. Just to confirm, you can easily pop open the case and take a look at the hard-drives. If you see a wide thin ribbon-like cable connecting to your hard-drive then you need an Ultra ATA (or just ATA or IDE) drive. It looks like this:
If a thinner red cable connects to your drive, then that is SATA. It looks like this:
May 13, 2008 | Dell Dimension 8300 PC Desktop
Difference between ata and sata hard disks
ATA, or (PATA) hard drives use the older "seatbelt" 40 or 80 pin ribbon interface cable, whereas SATA is fairly new using the small, thin interface cable found in most computers manafactured in the last 12-18 months, hope it helps
Feb 18, 2008 | Highpoint Technologies 1 Bay e.SATA...
Motherboard
Most of the new systems and motherboards support SATA connectors onboard. In your case there is none as you have found. So the best option is always upgrading to a new motherboard in case you need to add more SATA drives. You can also try to find SATA add-on cards, may a little costly types. These cards use PCI interface and very easy to install but hard to find one. I hpoe you could find one from a hardware store near you. If your motherboard has ordinary PCI slots then the SATA adpter will be less costly, otherwise (if it features a PCI-X slot) it will be costly. Following is a simple description on what the market has to offer: SATA II - 150 4Ports PCI-X with NCQ, Raid 0+1, Raid 0 and Raid 1 ! You can upgrade your desktop computer to have four Channels Serial ATA Generation 1 and Generation 2 transfer rate of 1.5 Gbps. The board provides a 64bit, 133 MHz PCI interface on the host side and four, fully compliant Serial ATA ports on the device side to access Serial ATA storage devices such as hard disk drive, ZIP drive, CD-ROM, CD-RW, DVD-ROM. Note: Fault tolerance: RAID 0 (Striping), RAID 1 (Mirroring), RAID 0+1 (mirrored-stripping) and RAID 1+S (Mirrored-Sparing) improve the data performance and provide the data redundancy and rebuilding.
Oct 09, 2007 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Dell Dimension 3100 PC Desktop Logo
1,519 people viewed this question
Alun Cox
