Question about Memorex MVDT2402 24 in. TV/VCR/DVD Combo
Won't accept tape
We push the tape in and it comes right back out
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
RETIME THE GEARS
Posted on Jul 17, 2010
HP SureStor DAT24 won't exit clean mode, won't accept tapes
give it cleaning tape >>> once it finishs cleaning it will eject cleaning tape then you will be able to put any other taps
Apr 08, 2013 | HP Surestore DAT24 DAT Tape Drive
Canon MV750i won't accept tapes. Help!
you read the catalogue or again you check it.
Mar 10, 2013 | Video Cameras
Red light blinking won't accept tape
If a tape "hung" up and it won't accept one you have a loading issue.
The unit may use a belt to drive the tray or a geared mechanism.
In any case someone needs to open the unit up to "see" what is happening. Most of these a tape can be inserted with power off and manually cycled into the unit to see the issue---we usually use a old cassette with the tape inside removed to avoid issues.
If you cannot do that consider looking for a shop who will (some no longer work on this type of equipment.)
Dec 05, 2012 | JVC BR-DV3000U DV/Mini DV VCR
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
I have a Sony Handy CAM 8 CCD-FX310. It will eject, but when you place a cassette in the slot and gently push it closed, the top will not retract down. it makes a slight spinning noise and then ejects...
I had the same problem with a Sony FX410, not much different than a FX310. With my camera all i had to do was to push the top down with a gentle push, it would engage and play and record normal. Don't force it hard, just a light pressure to help the cradle down. Most of these Sony cameras are crappy when it comes to loading the tape, most if not all the Sony's i've had end up with this problem, no matter what model you have. I've taken my camera competely apart and could not find the problem for not pulling down the tape, don't know if it can be a sensor or what, i never could find anything broken or loose or misalign, i oiled all the joints and moving parts with a light dab of thin oil, it worked fine except for that darn cradle not pulling down the tape.
Another thing that causes this is when the tape is to tight? In other words the tape should have a slight **** in it, i once ran into this big problem when the tape would not load and the camera kept ejecting it over and over. It was when i tried a new tape that i noticed how well it loaded yet the other tape wouldn't load. So i pulled out the tape and poked that little hole on the back right below the left hand pick up reel, i then turned the reel with my finger and gave it some slack, not much just enough to see the tape a little loose. I then reloaded the tape and it worked like a charm, seems that if the tape if to tight the camera won't accept it as the reels need to adjust back and forth for a few seconds, its that wacky sound you hear when you load a tape, seems like it has to adjust the tention inside the take up reels. Hope this might help you some?
Oct 08, 2010 | Sony Video Cameras
When i turn my xl 1s on and i put a new blank tape in it the red tape signal comes up on my screen, any help?
If you don't hear the normal sound, that the camara exept the tape, you problibly forgot to push in the tap of the tape receive mecanisme, before you close the cap. Closing the cap does not cause acceptance of the tape, like other camcorders.
May 25, 2010 | Canon XL1S Mini DV Digital Camcorder
Camera won't accept tape
tape senors is bad or have a bad tape
Jul 31, 2007 | Sony Handycam CCD-TRV308 Camcorder
Machine not accepting tapes
Just a thought : check if the head isn't blocked ! It should rotate freely (without any friction). I had more or less the same phenomenon (my VCR wouldn't accept any tapes and nothing was activated if I "pushed " a tape in). The reason was here that the VCR wasn't used for a long time (a few months), but it was plugged in all the time (heated up the interior). As a result the head was a-kind-of-blocked. Nothing serious, since I rotated the head manually my VCR works fine.
Feb 08, 2006 | Panasonic PV-V4611 VHS VCR
Memorex MVDT2402 24 in. TV/VCR/DVD Combo Logo
37 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
