Samsung ps42c91h plasma screen pc connection
When a vga cable is connected to the "pc" in on the plasma screen, it goes black and flickers the blue power light. my laptop is set to mirror the image and sees the samsung screen in the display properties. what must i set on the plasma screen to see my pc.
  • jbwallace Feb 08, 2008
    the laptop automaticially sees the samsung screen and sets the resolution to 60 hertz and 1024x768 and can't be changed. Still no picture!
    thanks,
  • pkhuynh27 Jan 18, 2009
    i have a 6o in samsung and trying to connect to dell laptop. i plugged in the vga cables and the tv is saying that there is no signal under the pc mode. help
    Master:
    Sergeant:
  • 440 Answers
U must use 60 herts 1024x768 on screen out ok try this
Posted on Feb 06, 2008
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Jan 31, 2016 | VIA Computers & Internet
Acer Aspire screen goes black every few minutes only when connected to tv
That may be because you have connected the incorrect VGA port to the TV, remember you need a VGA card installed on you PC with the correct cables VGA to RCA cables to get this right.
Feb 22, 2013 | Acer Aspire Computers & Internet
HOW CAN I HOOK THE Panasonic TH-42PX75U TO THE VGA OUTPUT ON MY COMPUTER?
If your computer has an HDMI socket, all you need is an HDMI cable. If not you need a VGA cable (the blue cable that usually connects a computer to it's monitor. One end goes into the socket on your TV marked VGA or PC. the other end goes into the monitor output on your computer. if you have a laptop, there will be a vga socket (usually blue inlay in the socket) on the side or back. you will then need to set up the second screen in Control panel, display settings. If using the VGA cable, you will need to run an audio cable from the speaker/headphone socket of your computer to your tv (there will be a 3.5mm jack near the VGA socket) or to your audio receiver.
Good luck.
Apr 15, 2011 | Panasonic TH-42PX75U 42 in. Plasma HDTV
My lap top screen went black but it looks like the computer is running? can i convert my laptop to hook up to a computer screen?
yes you can hook it up to pc screen just plug the blue vga cable into vga connection on laptop its usually the blue connection with pins
Oct 12, 2010 | Computers & Internet
The screen flick when connected to Samsing Sync
Hello there!
Screen flickering can be caused by instability of cable you are using, or it can be also caused by difference between power input, so check your power plug ,where your monitor and pc are plugged, make sure they are ok for your region, and check those cabels. Also check settings on monitor for what input you are using DVI or VGA or both at the same time.
Sinecerly
Aleksandar Adzic
Apr 16, 2010 | Computers & Internet
What cable connects my netbook to my tv?
Most plasma/LCD's have a PC monitor plug on it. Most laptops will have one too. (or even DVI, which is usually a white plug, and wider than the VGA cable)
Either way, i'm confident that you'll probably have the BLUE 15-pin standard VGA on the monitor and the computer. If so, buy that. If you have the wider white (DVI), it'll be even better!
Nov 20, 2009 | Samsung NC10-14ROBL Notebook
My flat screen Samsung monitor flickers on and off and goes to black for a few seconds before flickering on and off again. I tried taking out the cable connecting it to the computer and it still flickers...
Yes probably your monitor should be check by a technician. Try to see the warranty for you monitor if its still catch the warranty service for it, they may replace it. Bring it back to where you bought it.
Oct 31, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
PC won't turn on, blue light flickering, green light flickering
check your monitor's connection, its power and VGA connection to cpu, the cpu may be good but you just see black screen bec. your monitor remained off. please bring it to HP service center for more help
Oct 18, 2009 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
Samsung hdtv to compaq pc
There should be a setting within the comp. Is it connected to the comp monitor and the tv? Perhaps from the comp to the tv with the monitor from the comp as well? Well if so, you may need a certain setting within the comp. Check under (on xp) display properties, and then under the settings tab. Please rate!
Apr 28, 2009 | HP Compaq nx6110 PC Laptop
Televison & Video Logo
677 people viewed this question
Top Televison & Video Experts
