Whirlpool washer won't spin even though motor is running
Hi! please help. I'm a recently unemployed Mom with a Whirlpool "Thin Twin" (stackable washer/dryer) that I got with the house about 5 years ago (so its 5+ years old).
At the end of any of the wash cycles, it is suppose to spin the excess water out of the clothes. Even though the motor is running (it sounds like its trying), the inside part does not spin; leaving the clothes too sopping wet and heavy to dare try to dry.
  • WashingMom Feb 08, 2008
    Thanks very much. In this Whirlpool Thin Twin (stakable), there doesn't seem to be a belt. And the pump has rusted stuck (and is leaking a bit of water) .. so i've found a repair guy that will have to replace both the pump and something behind it.. agitar..? will see Sat.
Sounds like the the motor belt is worn or off. Try a new belt, or check the drain pump filter for clogs.
If you've got a handy friend, it's easy to check these... remove the back of the washer (about 12 srews) and check for black dust inside, or a belt hanging or lying on the bottom.
To check the drain pump filer screen, look for the drain hose, follow it into the back of your washer and down to a plastic bow looking unit. There should be a round cover with a kind of handle on it. remove the cover, (water may run out... have a few towels handy) clean off lint etc. and put back together. Try again...
Posted on Feb 07, 2008
Whirlpool Twin Thin Washer makes very loud noise on drain/spin.
Sounds like the bearing on the drum has gone , open the door and see if you have any play on the drum by moving it side to side and up and down good luck
Dec 13, 2017 | Whirlpool Washing Machines
My Thin Twin stackable washer & dryer Model # LTE5243DQ3 is having problems w/the washer spin cycle. I'm thinking I may just need a new timer because it goes through all the cycles except the spin...
Before wasting money on a timer that wont be returnable once it is removed from the packaging please respond to me and tell me does the washer do everything including draining, and the only thing it will do not do is spin
or will it wash but not drain and spin
their are 2 posibilities based on your response and neither is the timer
Thanks,
Gene
so ya know i have beena appliance repair technician for over 30 years
Jul 23, 2011 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
283 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
