Question about Toshiba e-Studio162 Copier
Toshiba e-Studio 162-Problem with Scanner
I can't get my computer (windows XP sp2) to recognize that there's a scanner. The computer will print using the e-Studio, but I can't get the scanner set up. When I use the network scanner tool setup, it can't auto detect a copier. I tried to add one manually, but I don't know the IP address or host name.
  • Anonymous Mar 16, 2014
    network setting
  • 32 Answers
Do you have the Ga-1170 kit?
Posted on Feb 14, 2008
SCAN
Install the viewer software that use for scanning
Jun 13, 2017 | Toshiba e-Studio 205 Copier
Tip
Toshiba estudio 162 e-studio 162 L1 L1-00 Error Code
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
on Sep 22, 2010 | Office Equipment & Supplies
Unable to access scan folder of Toshiba e-Studio 232 scanner from windows 7 system
Connect to copier/scanner using web browser. Click Administration tab, and logon use the copier's username/password. Click Network Click SMB Session Click SMB Session box In section called "SMB Signing of SMB Server", the default of "If client agrees, digital signature is done for communication" needs to be changed to "Digital signature isn't done for communication for the server" Click Set button at top, then Save button, and the copier will reset.
Nov 08, 2010 | Toshiba Office Equipment & Supplies
How do i use Toshiba e Studio 163 Copier as a Scanner ?
how can i use Toshiba E studio 163 as a scanner?
can print.. But can't Scan Anything even can't see the scanning opition or even icon..
Sep 29, 2010 | Toshiba e-Studio163 Copier
Computer can't locate my toshiba e-studio 162
Please dont try with setup wizard , please connect the usb cable between computer and printer then turn on the copier at that time new hardware found will appear, then you have to select YES THIS TIME ONLY. you have to select the driver location
May 26, 2010 | Toshiba e-Studio162 Copier
Is Software available for Vista?
According to HP, no. See link.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=59968&lang=&#
However, you might be able to install the Windows XP drivers and run the driver in 'Compatibility Mode' for XP SP2.
First, un-install any drivers you have installed for the scanner (if you have tried any).
Second, disconnect the scanner from your computer.
Download the driver and the software update from the provided link (above).
Once you have downloaded the driver (ps804en.exe) right click it, select the Properties/Compatibility Tab and check 'Use Compatibility Mode' and set it for Windows XP SP2, and also check 'Run as Administrator'
Then click ok.
Now run ps804en.exe and do not connect your scanner until the installation is finished (unless it specifically asks you to connect the scanner).
Now right click the updated software (ps803mu.exe),select the Properties/Compatibility Tab and check 'Use CompatibilityMode' and set it for Windows XP SP2, and also check 'Run asAdministrator'
Then click ok.
Now run ps803mu.exe
With any luck this might work.
Sep 25, 2009 | HP Photosmart s20 Film Scanner
Panasonic DMC-FZ18. Unable to download pictures to Camera and Scanner Wizard -
It would appear that DMC-FZ18 cannot reliably communicate with Windows XP. However if SD card is removed from camera and connected directly to computer there is no problem.
Jul 26, 2008 | Cameras
Scanner
Go to this link. Select Windows XP in the Select OS box. You will see Canon's printer driver for the BJC-2100, and under 'Software' you will see ISScan_v350.exe which is actually the driver for the IS-22, compatible with Windows XP.
Install and download both files on your computer. I know that Windows XP has a driver already for the BJC-2100, but it may not work properly with the IS Scan driver.
May 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Need driever for xp
have an Acer Flatbed Scanner Model 310P. I've had it for a few years and I really like this scanner. I just purchased a new computer and it has Windows xp as the Operating System. I cannot get the computer to recognize the drivers. How do I download the correct drivers?
Apr 27, 2008 | AcerScan 310P Flatbed Scanner
Won't install downloaded software from Canon
The software unzips to 'C' drive and should locate itself to the appropriate areas.
I suggest you get onto Canon support for this one.
Nov 01, 2007 | Canon CanoScan 8400F Flatbed Scanner
Toshiba e-Studio162 Copier Logo
1,035 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
