Question about Toshiba D-R400
After I record a TV program there is no video put there is audio
I cannot get a picture when I record. The sound is there but no picture. I am not sure if I have it connected correctly. There is not enough information on the set up for my configuration. I have a receiver and am trying to run it through it. Also on my TV I have Video and Audio "in" but no "out". How does the video from the TV get out to the DVD recorder.
  • 82 Answers
Get a coax to video converter with video in and out on it it will tell you how to hook it up which is common since you can get them at walmart and kmart run the coax of reciever into the ant in part run coax out to tv run rcas out to dvd player
Posted on Feb 06, 2008
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
DVD-VR357 RECORDS VIDEO (FROM VIDEO1) FROM COX DVR, BUT NO AUDIO
well there the first thing i would check is the audio connection..
basically if you are recording from a playing media, like a dvf player
it would be like this
audio and video out from the dvd player to the inputs in the recorder.. then the out puts from the recorder to the input in the tv... (just a refrence)
upload your diagram, and state exactly what you want to record from.. if its the tv or another media type..
If its from the tv,, lets say you got cable and you want to record from cable,, Its
connect the out put from the cable box to the input of the dvr, then the out from the dvr to the input of the tv..
or
if its from an arial
connect the arial to the dvr,, now connect the dvr to the tv,, I guess you got the picture of what i am saying..
Basically all the out put from the media you wish to record from to the DVR and then from the DVR to the Tv..
Feb 22, 2008 | Samsung DVD-VR357
I have sound but no picture on the screen.. What did i do wrong
Hello sir, hi, please check the video cable. If you are using the three color audio/video cable, the yellow one goes to the yellow input of the TV to the yellow output of the DVD recorder. Then check the TVs audio video settings, the TV should be in the video channel, if there are several video channel, check where the video is coming in. Make sure that the yellow cable is good. you can swap several cables to check.
If your TV is component input, put the red green and blue wires to their respective color port, one end is on the DVD recorder, and the other on the TV. make sure your cables are good. Do the same thing with the S-video and HDMI cable. if your TV has this.
Nov 21, 2009 | Daewoo DVRS05 DVD Recorder/VCR
How can I get audio and video out from my tv if it only has audio and video in.I'm trying to connect a dvd recorder to record programs off the tv but tv does'nt have output signal.
connect dvd input cable (three banana plugs red, white, and yellow) to the video and audio output on a vcr, then take a screw on cable from the Ant. to the vcr. you will have to tune the vcr to the programs channel to record the picture. The vcr manual should tell you where the signal will be going, The picture should also go to the tv on ch 3 or 4 as when you play a vcr tape.
saddikins
Aug 05, 2009 | Televison & Video
Cant capture sound with DVC 90 with vista
Make sure you check the recording source for audio and also the volume levels. Check the default audio input settings in Vista as well as the audio recording source in the recording program.
Jules
Dec 17, 2008 | Pinnacle Dazzle DVC 90 (210100371) Video...
Running my tv throught my vcr but have no picture only sound
You don't say what kind of tv,model,etc. or if the tv tuner is 'solid state', push button, knob type channel changer.
If you REALLY, REALLY have to use the tv through the vcr.place the signal [antenna, cable box, cable antenna (signal) in vcr RF input.place a blank vhs tape to record, use the RCA jacks[AUDIO & VIDEO] in back of the VCR to INPUT of TV video & audio ( if you have then ) While you are recording, you will be able to see the tv program.
p.s. place the TV\VCR switch to vcr.
Dec 14, 2008 | Televison & Video
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
Windows Movie Maker
A lot of times Dazzle provides a calibration program for video and sound. See if you can run that.
There usually is a seperate audio capture control. If you go to your sound mixer and check the recording settings, is the audio capture from the Dazzle selected?
Jun 08, 2008 | Pinnacle Dazzle DVD Recorder
Records media but playback has no audio.
Are you absolutely sure that it is receiving an audio signal?
What input are you using? Try recording using alternate inputs.
Audio part of a VCR is normally way more reliable than the video.
The exception is on high-end stereo types where they record the extra audio signals using the video head cylinder in which case it can easily be lost.
Jan 24, 2008 | GE VG4054 VCR
PICTURE ON TV
DVD should be connected to an input on your tv not the monitor out.
Dec 01, 2006 | Marantz SR8500 Receiver
Open Questions:
Toshiba D-R400 Logo
122 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
