Question about InFocus ScreenPlay 4805 Multimedia Projector
InFocus My problem is that when I turn on the projector, I get a speckled black and white screen but no real images. The LED is green and I can't get anything to happen with any of the buttons. Any ideas?
  • peasy easy Sep 23, 2012
    Hi I have a similar problem monochrome image... the screen starts with black horizontal bands.. then speckled white dots appear and fill the screen.. and slowly grow.. I press the keystone keys and the amount of white speckle changes so the buttons work .. to an extent... also connected to a vga and played movie, the projected image flickers as the movie plays.. the audio is fine through the projector... Please help I hope its just noise from the 680uf 16V caps in the power section and hope not a mainboard fail! :-)
Posted on Sep 23, 2012
  • 563 Answers
Hi there
That is a definate Mainboard replacement.
Must warn you that it could turn out to be a expensive exercise
Posted on Mar 27, 2008
Green screen on VGA with Viewsonic PJD5122
VGA is separated analog signals in Red, Blue, and Green. Under normal cases, you'd be able to change the cable, source, or input port and resolve the issue. Unfortunately, if the green tint persists with all input ports on the projector (The two blue ones are Input, the black one is output. There is a potential that attaching input to the black output port could have caused the damage), different sources, and different cables, then it's likely a problem with the projector hardware itself and would require warranty service or otherwise repair or replacement of the projector. If you have an alternate way the projector can be attached, then try that (Such as SVideo), otherwise there may not be any good solution in this case short of checking the guts of the system.
Mar 28, 2014 | ViewSonic Office Equipment & Supplies
I have a Sanyo PLC-XP50 projector and my words on the screen are showing up white with purple speckles, when I want them just to be white.
there are a lot of dust on the Lcd panel
3 panels (red ,blue,and green) in the Projector
purple speckles means that the dust on the Green ,
1,pick the Lcd prism from the projector
2,clean it by putting it into water,with some cleaner
3,dry it with a hair dryer
4,ok
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 19, 2014 | Sanyo Office Equipment & Supplies
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Office Equipment & Supplies
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Black and white specks from InFocus X1 projector
if you can get a menu when you press the menu button, reset the settings to factory default. if you don't get a menu, the color wheel or the dmd chip is bad. either way, you'll have to replace the entire optical engine. and unfortunately, infocus no longer has any more in stock.
Sep 06, 2009 | InFocus X1 Multimedia Projector
Infocus X3, no light, LED is solid green.
the colorwheel. if it does not spin, the lamp will not light.
Aug 26, 2009 | InFocus Proxima UltraLight X350 Multimedia...
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
Flaws, Speckles and smal white & black lines on the screen
might be a ground issue. plug it into other outlets and make sure the ground prong is still attached to the plug.
Mar 25, 2009 | Office Equipment & Supplies
InFocus ScreenPlay 4805 Multimedia Projector Logo
304 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
