Question about Intel Motherboard
Prog not starting up
Have a 85661FXM-RZ mobo that starts up but will not go into windows. Keeps reporting "Start windows normally" etc... Yet the HD will start in the other comp. Solution needed asap!!!
  • t1mz_hou Apr 06, 2008
    hey aceltix
    many thanx. I needed a newer version and it worked a treat.
    Scholar:
  • 119 Answers
Hello
its is a quite coomon problem,and the cause can be both the hdd and the windows itself.
if you said that the hdd is ok,try to install a new version of windows
for me iit worked almost all the time.
but to be sure first check the cable settings in the computer,all the connection,check the ramm dims and the bios setiings.if all seem to be normal,try a fres windows.it will fix your problems.120%:)
the registers of your windows are damaged and thats why you need a new version..
bye bye
Posted on Feb 06, 2008
My laptop wont come on a screen keeps coming up asking to repair or start windows normally i have tried both without success
When was the last time you were able to use your computer?
Did you installed any software recently in your computer?
Try pressing F8 on startup and use the Last Known Good Configuration. May be that will help.
Feb 28, 2011 | Toshiba Satellite Laptop L655S5150
Xp not loading, new mobo, new hd, can't get xp to load, its starts but freezes up every time
first of all you should try in safe mode i give you step restart system press F8 key continue the start system in safemode after that if you are able to start system in safe mode then restart the system in normal mode may be your issue will solve, if not solve then repair or reinstall your XP
I hope this has been very helpful for you
Dec 05, 2009 | Foxconn NF4UK8AA-8EKRS Motherboard
Display problem after xp splash screen
try to decrese the Resolution.
800 X 600
or
1024 X 768
plz rate this post.
Feb 09, 2009 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Start Normally (black screen with options)keeps re-loading itself
If you can't get into windows normally or into safe mode to try to restore the system back to a date when it worked properly then you'll need to wipe out the hard drive and start the system from scratch.
Feb 08, 2009 | Compaq Presario SR1050NX (DW257A) PC...
Computer won't start
this is a complicated fix to diagnose over emails but first, the hd had been hit the power outage while accessing the hd can damage it. so I recommend reloading windows fresh if it cannot then you may have damaged the cd rom /dvd drive.
what version of windows are you running?
Apr 27, 2008 | Computers & Internet
Have a hp computer, cleaned registry, also defraged hd
This could possibly be caused by a failing power supply or cpu heat sink,Also,check to be sure memory boards are seated properly.
Feb 16, 2008 | Computers & Internet
Can't load Windows, constant restarts.
There could be several issues, but random restarts can be difficult to debug. For now, I'd start with the easiest and that is a memory check.
Visit www.memtest86.com and download the free bootable floppy or CD (burn the ISO file with free ImgBurn utility if you have no ISO burning application).
Boot the problem system with the floppy or CD and the memory test should start automatically. Let it run over night and see if errors are reported.
Dec 19, 2007 | ASUS P5P800 SE Motherboard
Upgradation for vista
Gigabyte 7VM333M-RZ - motherboard - micro ATX - KM266
There is a cool way to find out just what it takes to run Vista on your current system. Download and run MS Windows Vista Hardware Assessment. It will help you prepare and suggest just what you need to upgrade either hardware or software. Make it simple! Download below.
http://www.microsoft.com/technet/solutionaccelerators/hardwareassessment/wv/default.mspx
Dec 11, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Intel Motherboard Logo
29 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
