Canon 5700 how do you cancel print jobs once started.
    Problem Solver:
  • 18 Answers
Well, first make sure that you're most recent drivers and manufacturer's software packages are installed - this will guarantee success.
Under the Control Panel (this is in Windows XP, correct?), Printers and Faxes, you should see your printer, Canon 5700 Series or something of that nature.
Double clicking on it will result in an open Print Queue, where you can view, cancel, or pause any active print jobs that are spooling for this printer.
If and only if you have the most recent drivers installed, there will be a dialog box that pops up detailing ink levels, etc, and will have a "Cancel Print Job" button on it.
Posted on Feb 06, 2008
  • 82 Answers
Usually there is an icon that will pop up in task bar by clock double click it and the click cancel
2 Suggested Answers
SOURCE: canon 5700. how do you
my canon 5700 dont wanna print ,the fax end scaner worck .
Posted on Oct 07, 2008
Where is the cancel button?
Most printers don't have a cancel button. You get to "cancel" by going into your computer START menu then selecting CONTROL PRINTER then select CANCEL PRINT JOBS. In the future, I found the safest way to avoid accidentally printing more than intended is to always select "Current Page" when ordering a print job.
I hope that helps.
Mar 03, 2015 | Canon PIXMA Office Equipment & Supplies
How do you stop a print job on a canon printer ?
To stop a print job of your canon printer. Click Start, Printer and Faxes. double click the default printer which check icon. Right click the print job and chose cancel.
Jul 28, 2010 | Canon MX310 Office All-In-One Printer
My MF 5700 has a red lamp blinking and notification-check paper size constantly, even when I restart it, wont print anything, paper size is ok...
If you are printed on it, check the paper size under printer properties, to "get rid" of blinking cancel job or print, copy and turn off and on
Jan 13, 2010 | Canon Office Equipment & Supplies
How can I cancel a large print job, that has started?
There are two ways to stop the job.
  1. Click the cancel button on the printer
  2. Go to Start > Printers and Faxes > Double click on the printer that is being printed on > Right Click on the job you want to cancel > Press Yes
Jan 12, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Have a print job in the printer that i want to cancel. have unplugged the machine from the network, unplugged the machine from power. when i turn power back on, it start printing 500 page job that i do not...
Press the [PRINT MONITOR] key in the lower right corner of display. If fascimile option is also installed, it would say [SYSTEM MONITOR] key in same location. Anyways, after in print monitor screen, select the job that you want to cancel and press [CANCEL] key. Press [YES] to cancel. Press [DONE]. You might want to pull out all of the paper trays so the machine can't print while cancelling documents. Let me know.
Nov 02, 2009 | Canon ImageRUNNER 330s Copier
How to cancel past jobs on ip90v printer
The jobs don't stay in your iP90, it has a limited memory for just what is printing, every time it powers down all past jobs are lost. You need help with OSX and not a printer tech.
Aug 20, 2009 | Canon PIXMA iP90 Mobile Printer
How to cancel a print job
to cancel a print job click on the start button then go to control panel and thento printers and faxes you will see the name of your printer right click on that icon and select cancel all documents
confirm the cancel and select yes
if even after doing this step 2-3 times the print job is not cancelled then click on start in run tupe services.msc then in the window that will open up look for print spooler and then right click on print spooler and click on stop
now unplug the usb cable from the printer and restart the computer after restart go to the printers folder and then see if there are any printjobs
is still ther are any right click on the printer folder and select cancel all documents
and now connect the usb cable
Aug 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Canon 5700. how do you cancel print job mid way.
Feb 06, 2008 | Computers & Internet
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
