Question about Acomdata E5 (HD080FE5-72) 80 GB FireWire 400 (1394a) Hard Drive
Acomdata hard drive Model HD320FES-72
Turned on the computer last week and it does not recognize my F: drive with the Acomdata firewire connection. Help! It has all my music. I have reconnected everything and restarted and sent several e-mails to Acomdata to no response.
  • schoduck Jun 01, 2008
    Hard drive will no longer mount. Has crital BU data. HELP!
2 Suggested Answers
zzptichka
  • 95 Answers
SOURCE: Acomdata hard drive Model HD320FES-72
Sounds like the drive has seized spindle... Not good news.
Is it buzzing similar to any of these noises: http://datacent.com/hard_drive_sounds.php ?
What you should do is remove the internal drive from the enclosure and connect it directly to the computer. If still buzzing then it's a real mechanical problem...
Posted on Nov 03, 2008
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Acomdata external hard USB hard drive model HD160UE5-72 worked fine then suddenly the device was not recognized. Reboot with unit powerered up and the device is not detected. Blue LED is on, tried...
Either the hard drive is bogus or the electronics of the external adapter is the culprit. Take out drive and hookl directly to mo bo as a secondary drive. If recognized drive is ok and the box is at fault.
Aug 25, 2017 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Acomdata 250 external (SATA) hard drive not showing up on desktop
be safe
go on line to acomdata web site and down load the driver from there
Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
Acomdata HD500uhe5-72 cant be seen . on XP
Put it in the freezer overnight in a bag. For some reason it might be stuck in a read mode. Just because you did not tell windows to stop the drive does not mean you hurt it. When you go to use it again,
plug it in and turn it on, you should hear the drive start to spin, if not
you could shake it and see if it starts. Then after it is plunged in
and plugged into the pc, start the pc and wait till after windows is up and running, after 3mins, if not seen unplug, firewire and plug it back in and wait a few mins. If nothing, contact the company and see if it is still under warranty. I hope this helps you. Any other questions,please post back,everyone is more then happy to help you.
Feb 11, 2009 | Acomdata 500GB External Firewire HD 500 GB...
Nov 02, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Connection
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Jun 27, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Acomdata no longer recognized
Check your USB Cable connected possible lost contact problem or the power supply of your optical drive.
Hope this will be helpful to you.
Oct 25, 2007 | Acomdata E5 (HD080FE5-72) 80 GB FireWire...
Acomdata E5 (HD080FE5-72) 80 GB FireWire 400 (1394a) Hard Drive Logo
56 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
