Question about Dell Inspiron 2200 Notebook
Dell Inspiron 200 power jack
Replacing the power jack on a Dell inspiron 2200. Does this plug in or does it require to be soldered? Different answers so far.
  • 689 Answers
Yes if you are talking about the socket at the computer it requires old one to be desoldered and replacement part should be soldered firmly.
Good Luck
Posted on Feb 06, 2008
Dell inspiron elec cord isn't firm so power turns off
Maybe it's the DC Jack that the power cord plugs into. If the jack is loose then you will experience the issue you are having.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 18, 2012 | Dell Inspiron 1525 Notebook
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
Jan 04, 2011 | Dell Inspiron 6000 Notebook
Is there an easier way to replace a dc power jack than soldering it? On an Inspiron 2200.
no
i'm afriad not my friend -- i have desoldered and soldered many DC jacks for Acers, dells, HP, IBM
Dell are some what eassiest, for most notebooks..just make sure
here is a video to help you
http://www.youtube.com/watch?v=1q0ln61p4hY
please rate my service
Nov 10, 2010 | Dell (8N816) Motherboard
Have a dell inspiron 1525 that will no longer charge, replaced battery, charger and power adapter card in laptop. What can problem be - read that it can be some capacitors. Where are they and how do I...
Tom
i have inspiron 1525 as well ... if the computer wont boot up, then the mainboard may have experienced a power surge of excess current. did you have t-storm or power out while your computer was plugged in with Ac adapter ?
if not , to answer your question, the capacitors you inquire about are so small, it would require special solder machine to replace these CAPACITORs, as they are very tiny in size and require absolute temperature (heat) from solder gun to pally appropriate solder to replace the capacitor(s).
i think your mainboard is gone.
if i can be of further assistance, please let me know-- i can help
Nov 02, 2010 | Dell Inspiron 1525 Notebook
Have a dell insprion 9300 Will not charge the battery I have two of these laptops ones the e1705 and the 9300 batterys are the same as watts does the same thing with both batterys it will run on battery...
The jack on the laptop that you plug the AC adapter (Charger) into, is called a DC Power Jack.
http://www.laptopjacks.com/view_part/Dell-Inspiron-9300-Laptop-DC-Power-Jack-DL111500.html
I would like you to click on the photos of the jack. (3 views shown. Has www.laptopjacks.com on it)
The middle photo, and the photo to the right, shows copper prongs that protrude out of the jack.
The view to the right shows the jack upside down, in relation to how it's mounted on the motherboard.
The prongs go through the motherboard, and are soldered to circuit traces on the motherboard.
(For simplification, think of circuit traces as being very thin flat copper wires on the motherboard)
There is data stating that the solder joints have a tendency to crack, even with normal usage of just plugging, and unplugging the AC adapter.
It is also stated that the motherboard area where the DC Power Jack is mounted, is of a bad design.
Many have had the motherboard replaced, ($400 to $500), only to have the same problem come up later.
It has also been stated that the manufacturer states replacing the AC adapter, but has been shown to no avail in solving the problem.
Same thing comes up for the Dell Inspiron e1705.
(I know, I'm just a 'Ray of Sunshine')
A cracked solder joint, or cracked solder joints make an intermittent contact. When the DC Power Jack is in a certain position with the AC adapter plugged in, the contact may be good. Moved around by plugging in the AC adapter again, the position may change, and result in an intermittent contact, or no contact at all.
Result?
Laptop will not power off of the AC adapter, nor will the AC adapter charge the battery.
This is the reason why the laptop will run straight off of the battery, but the battery isn't being charged back up.
It could also be that the damage is further than a cracked solder joint, or cracked solder joints.
One of the prongs could have come loose from it's mounting, and no longer be attached to the pin it's supposed to be attached to.
[ The AC adapter converts AC {Alternating Current} electricity from your household, or business, into DC electricity.
{Direct Current. Batteries are an example of stored DC electricity}
DC uses two connections. A Positive connection, and a Negative connection.
One of the prongs is for the Positive connection, another one is for the Negative connection. The other prongs are used for stability, to mount the DC Power Jack in place to the motherboard. Generally the center pin/s are for a Positive connection, the outer pin/s are for the Negative connection ]
Unless I had the laptop in my hand, I can only give you a generalization of what may be wrong, and the possible solution to repair it.
1) All power to the laptop removed, (AC adapter and Battery), see if you can wiggle the DC Power Jack around. Any perceptible movement is bad.
2) Past this point the laptop will have to be completely disassembled, down to the bare motherboard in your hand. Requires visual inspection of the solder joints for the DC Power Jack, and the surrounding circuit traces.
It may be something as simple as resoldering a cracked solder joint. (Or joints)
It may go further into replacing the DC Power Jack.
It may still go further if the area on the motherboard where the DC Power Jack is mounted, has cracked.
You or a tech may not be able to mount a new DC Power Jack.
This would require a workaround, IF feasible. Won't be aesthetically appealing, however.
http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
Dell Support > Inspiron 9300 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Older Dell Inspiron 1300 laptop, but linked to show you more about replacing a DC Power Jack, and the required 'little things'. Such as properly cleaning the solder joint area on the circuit trace, that a prong for the DC Power jack, goes through, and is soldered to.
http://www.insidemylaptop.com/remove-motherboard-repair-dc-power-jack-dell-inspiron-1300-b120-b130-laptop/
You may find this useful also,
http://www.coredatarecovery.com/how-to-repair-a-bad-power-jack-on-a-dell-inspiron-51501100-series-laptop-for-under-2000/
Click on - Dell 5150/1100 series Slideshow
(Author Charles House)
1) Buy an wear an ESD wrist strap. (Electro Static Discharge) The average cost is around $3 to $8.
Connect the alligator clip to a good ground source. I connect to the metal frame of an empty desktop computer case.
Observe Anti-Static Precautions.
[Your body carries static electricity. Static will fry out (Short Circuit) the hardware components inside a computer. Wear the ESD wrist strap, and connect it to a good ground when working on the laptop.
Should you leave in the middle of working on your laptop, upon your return be SURE to put the ESD wrist strap back on ]
2) There may be as many as 60 screws, and 12 different types of screws. Do Not mix them up.
Use a multi-compartment container for the screws. Mark each compartment for the area the screws came out of. Do not stack them neatly on a table. Recipe for disaster.
You can use a clean egg container in a pinch. Mark each egg holder.
3) Use Solder Wick, (Desoldering Braid) to remove the old solder. Do not use a Desoldering Tool.
4) Make sure the area of the circuit trace that you have removed solder from is CLEAN. The links above will detail more about this. Make sure the circuit trace areas are pre-tinned with solder, before inserting the DC Power Jack's prongs. Don't worry if the hole in the circuit trace is covered with solder from tinning.
You can heat it up to insert the prong. (One prong at a time)
5) DO NOT linger too long with the soldering iron, (40 to 50 Watt) This can render a circuit trace useless.
It will burn it, (And the motherboard), and render the circuit trace useless from accepting the tinning.
(Solder it applied to the area to be soldered in a light coat. = Tinning)
Linger too long, and you can lift the circuit trace right off of the motherboard.
For further questions please state in a Comment.
Regards,
joecoolvette
Oct 27, 2010 | Dell Inspiron 9300 Notebook
Dell Inspiron B130 - can you replace the connection for the power source/battery charger? Mine is shorting out and not always charging the battery (new battery, new AC cord and adaptor).
Yes you can replace the power adaptor. You may also remove the solder from the existing adapter and re-solder it back on which is what I did. If you just want to replace it I suggest Ebay before I repaired mine I ordered a new one for $5 w/ free shipping.
Dec 29, 2009 | Dell Inspiron B130 Notebook
Dc jack broke. tech guy replaced but now none of my 3 power bricks will charge the battery. they all give power to run laptop but do not charge battery. when boot up get error message saying I connected an...
It is possible that it could be a bad solder joint. It could also be that the connector is a different one. Some laptops use a dual voltage power structure. On the Inspiron E1505 (same as the 6400) I have it requires the dual voltage power. This is where the outside of the plug is the ground and the inside of the plug is one voltage and the center pin is yet another voltage. In this case, (if I remember correctly) the inside of the plug is like 19.5 volts and the center pin is like 9 volts. The inside of the plug supplies the power to the laptop and charging circuit and the center pin tells the laptop that the power adapter is plugged in and should start charging. If the laptop recognizes the Vostro power supply then this is a good possibility. Either way, it is worth getting it checked out. The last thing you want to do is burn out the charge circuit on the motherboard by having the incorrect power supply plugged in to it. It may work for a while or it may work forever but you never know.
Dec 24, 2009 | Dell Inspiron 6400 Notebook
Computer doesn't accept power
check the metal post inside the power jack connection. very carifully try to wiggle the metal post and see if it moves or if its there at all. if the post wiggles, it is probably broken and needs to be re-soldered...only someone who knows how to do that should as you could damage the board trying yourself.
also try plugging it in without the battery.
do any lights come on at all when its plugged in or power buttons are pressed?
Mar 28, 2009 | Dell Inspiron 2200 PC Notebook
Open cover to resolder power jack
You will need to remove the system board to gain access to the power jack. Here’s the link for the Inspiron 2200 service manual: http://support.dell.com/support/edocs/systems/ins2200/en/SM/index.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 2200 Notebook
DEAD DELL
Replace the DC Jack, the battery will may charge if it doesn't get power from Positive and Negative. On that particular model it is usually the positve terminal. Insufficicent solder at production time causes a weak joint, repeated plugging in weakens the joint even further until it breaks the connection. If you have not damaged the jack badly, you may be able to get by with a simple 'reflow' of the solder. Use flux paste and add about 1 drop of solder to the terminals. Being careful not to short POS & NEG. (the contact pads are very close- use magnifying glass to verify)
Most likely the burning smell was the solder arcing around a poor solder connection.
I would suggest verifying DC jack before spending good money on a battery, since most LI-ION batteries are good for upto a thousand charges plus...
Mar 14, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
156 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
